Kumho Ecsta V700
Discussion in 'Wheels & Tires' started by goaljnky, Sep 15, 2010.
  1. goaljnky
    3,105
    394
    Anyone have any first hand experience with these for track use?
  2. YesIFit
    YesIFit New Member
    May 25, 2009
    231
    Not the 700's .. just the 710's. They're great.
  3. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Yup. Good, durable track tire. I would recommend them for the track-day junkey. If you are racing for tenths of a second, and money is no object, the Hoosiers are probably a bit faster. With the V700s you won't be buying new tires every weekend as well.
  4. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    If you can run 15s, tirerack has a close out on the 205/50/15s. I got 4 coming to the house now. I expect them to be faster than 225/45/15 NT-01s and last 3 DE weekends - same as NT-01s.
  5. goaljnky
    3,105
    394
    They are also having the close out on some 17's. That's what I am considering.
  6. Alan
    Alan Active Member
    98
    V700s mounted and balanced, and loaded in the MINI. Off to TWS tomorrow. Mine had 5009 date code - fiftieth week of 2009.
    I plan on changing tires Friday night at the track and scuffing them up good. Then tiptoeing the first session Saturday. Second session they should be good to go.
  7. agranger
    I just went to check these out and just noticed the 710W tires... R-Comps specifically cut for the wet. Very nice!
    The price on 215x45x17 on the 700 was $105/tire... not bad for DOT-R tires!
