1st Gen JCW Leaking Turbo Oil Inlet Line
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by CHKMINI, Dec 5, 2011.
  1. CHKMINI
    This past weekend we discovered that the inlet oil line to the turbo was leaking and spraying oil directly on the turbo. Apparently the crimp joint has an o ring that dries out from the intense heat of the turbo and fails. The line has to be replaced. In fact, the '12 models now have a clip on heat shield attached at the fitting end to reduce the heat soak at the crimp joint
    I have a '09 JCW with 76,000 miles. My dealer has now informed me that the return line is leaking as well. From my perspective this is a poor design that MINI needs to replace under warranty/policy but at the moment I'm looking at an $810 repair bill.
    Does anyone have any insight to this issue. Service Builletins, lawsuits, repairs, etc. that I can use as documentation to MINI in an effort to get them to pay for their design flaw?
  2. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    On post #29, you'll see that I've at least encountered this, later in the thread a couple others reported the same leak, and I know of a couple warranty replacements locally. However, not all R56 turbos get a leak. Negotiating a reduction in labor may be possible based on the commonality of this leak, plus the dinky heat shield was not available for your model, and the pipe crimp was redisigned after 09, but "design flaw" will be difficult to argue. I think it is more likely the line was installed at an angle causing an uneven seal, rather than unshielded convective heat causing an O-ring failure. Conductive heat from the turbo housing is extensive as is.
  3. CHKMINI
    Thanks Keith! I've registered my official complaint with MINI...at least I didn't right it on paper and waste time AND trees. IMO this line should be a stainless flex line with a straight banjo fitting and not the crimp fitting that they use.
  4. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Okay, that is a genuine concern for me. You said they changed it but did that change happen in '10 or '11 MY? Keith, how much of a pain is this to repair once it happens?
  5. k-huevo
    159
    Pipe Creek, Texas
    I don't know the date the part changed. You can compare the one your car to the one in the photo (09 JCW) to see if the crimped end on the fitting is shaped similar.
    I recommend lifting the front and removing the front wheels to start, the bumper cover and bumper are removed, the radiator support & lights are placed in service mode. From here I'll borrow a descriptive post:
    When I replaced the piping, I had the turbo and manifold removed along with the radiator support for additional tasks.
  6. CHKMINI
    I had both lines replaced today. The inlet was leaking at the crimp fitting and the return was leaking too. The turbo had to be removed as well as the bumper and radiator. Total bill with parts and labor $730. I'm going after MINI for a policy adjustment. The dealer did a great job, got me right in and got me on my way in about 6 hours. This is a senseless repair if the original line was stainless flex with banjo fittings instead of the crimped fitting POS!!!
  7. MINI Fireman
    MINI Fireman New Member
  8. Metalman
    Mark, after they replaced your turbo oil line, did they attach the oil line heat shield? Or did they only replace the oil line?
  9. CHKMINI
    They added the oil line heat shield too.
  10. Metalman
    Hmmmmm.....
    Is that MINI's way of saying it's a defective design without the heat shield?
  11. Thunderball Kaboom
    Thunderball Kaboom New Member
    Aug 17, 2010
    49
    I am the Coordinator for a program that provides h
    Live and play in Central Phoenix - Camelback corri
    I have been informed of a similar issue during a complimentary service review event at my dealer. Quoted $720 before a 20% discount.
