2nd Gen R56 Cooper Left for longtime
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Mar 11, 2012.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    If an R56 is gonna be left in the garage for more than a month or more without being used
    1. what issues might it encounter since the engine will be "sleeping" for a long time?
    2. what is the best way to prevent from these issues to happen?
    3. will disconnecting the battery be a good way to solve the issues or might it effect the electronics of the car?
    I would disconnect the battery. I'd fill the tank too. You should have no problems.
  3. Minidave
    4,596
    I would NOT disconnect the battery, instead I'd put a battery minder on it to keep it fully charged and all the sytems on the car enabled. I'd also put fresh oil in it (unless it's been changed recently) and fill the tank. Other than that, it should be good to go.
  4. genik
    genik Member
    Feb 20, 2012
    402
    19
    why not disconnect the battery?
    why fill the tank?
    why put fresh oil?
    just asking for the right answers
  5. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    It might not hurt to put some gas stabalizer in when you fill it to prevent varnish build up in the fuel system.
  6. genik
    genik Member
    Feb 20, 2012
    402
    19
    varnish?
    A full tank of fuel will help prevent condensation from building up in the gas tank.
    Fresh oil is just that, it doesn't have the acids that build up in used oil over time. Helps to keep things fresh and clean while it site.
    If inside a garage or storage space with access to electricity a battery tender is a darn good idea. MINIs always have some electrical draw. Long term sitting will drain the battery. If there is no access to electric then I would pull the battery.
    Gas goes bad, modern fuels that we have now take longer then they years ago but they still go bad. Over time the voluble compounds in gas break down. One of those is a nasty sticky gum like varnish that can really mess things up. This was more a problem some time ago where it gum up the floats and jets in carbs. It can still cause sticking injectors and deposits in the fuel lines. A fell tank helps reduce the speed at which this happens.
    As others have said something such as Stabil will also help prevent the gas from going stale.
  9. genik
    genik Member
    Feb 20, 2012
    402
    19
    Can a month o inactivity drain the battery?
  10. DneprDave
    A month? No.
    I've left my MINI sitting for a month with no problems.
    Dave
    Yes a month could cause your battery to be flat. That is why I recommended pulling the negative cable off the battery. If it is only a month I would not worry about clean oil or fuel stabilizer. Long term storage requires a bit more thought.
  12. Herleman
    Herleman New Member
    May 25, 2010
    51
    42
    I've left mine for more than a month several times. No issues whatsoever upon my return and my only "preparation" was to empty the trash out of the door pockets and take the iPod with me.
    The little car fires off after over six weeks like it started yesterday. The only thing i noticed at all was some squeaking/grinding as the rust wore off the brakes.
    Remember, these little cars can often sit for a month at a time in the ports or on the deasler lots, especially on the dealer used car lots. They are really pretty sturdy little buggers.
  13. Rockridge
    Rockridge Member
    Oct 12, 2009
    32
    Director of Software Development
    I agree with Herleman. I store my car very winter, and have done now for 4 winters. The car sits for an average of 4 months. Each time, when a nice day in March shows up, I have just got in the car, started it up, and drove it away. No issues.
  14. Minidave
    4,596
    And yet......when I bought my Clubman my '03 often sat for a few months without being started till I got it sold - sometimes it didn't start, sometimes it did......
    The other factor is whether the car gets driven far enough after it's slumber to bring the battery back to full charge.
    A $35 battery minder means you never have this problem - ever. And your battery will last longer.
    For one month you probably don't need to do anything but park it indoors if you can, I thought you were laying it up for much longer.
    I still wouldn't disconnect the cable.
  15. DustinT
    DustinT New Member
    Sep 24, 2012
    15
    The nice thing about a battery minder is they're less than $20 and tend to last for many years. They work on motorcycles, cars, law mowers, etc... They will prolong the life of the battery.
  16. MCS02
    6,278
    I would just add that fuels with ethanol absorb moisture like a sponge. Before I sold my dirt bikes the gas would go bad over a short winter. My boat always gets sta-bil for the 3 months it sits up. It's cheap insurance.
