1st Gen R50 Cooper Let there be light
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by LANLOC, Oct 2, 2011.
  1. LANLOC
    LANLOC New Member
    Oct 2, 2011
    St. Louis, MO
    #1 LANLOC, Oct 2, 2011
    Hi folks,
    I am trying to replace a front 5 watt parking light on a 2002 base mini. I can get part of the wiring horness out but not the light blub itself. Any suggestions?
    Good motoring!
    Brock
  2. Metalman
    Do you have a R56????
    If so, you're talking about the light bulb just above the fog light..... Correct?
    I replaced mine and it was difficult to do as well.
    Rotate the plastic bulb housing counter clockwise. you'll feel it rotate and then hit a stop. Don't force it anymore... It should then pull right out. If I remember correctly, there is a rubber weatherproof gasket that you need to overcome as you are turning the housing. If they have been in there for awhile, they tend to stick.
    Make sure you get all the tabs to engage when you put back the wheel well splash covers. If not, they will fall off.....:D
  3. LANLOC
    LANLOC New Member
    Oct 2, 2011
    St. Louis, MO
    Sorry brother, I didn't give enough info. It is a 2002 base. Thanks
