Life Choices
Discussion in 'General Chat' started by InstrumentOfPeace, Jan 13, 2020.
  1. InstrumentOfPeace
    InstrumentOfPeace Active Member
    Jan 10, 2020
    106
    69
    Do I:
    a. buy a MIG welder & accessories (helmet, clothing, fiberglass blanket, pipe bender, etc)
    b. buy a 3D Printer
    Aside from the Mini, I own a ‘92 Samurai which I hope to keep for at least another 9 years for my daughter. I recently finished an engine swap (engine, wiring harness, ECU) and plan to lift a few more inches with an eco skeleton (hence the MiG welder)
    One constant is a continuing need for either small plastics bits & clips that I could print (panels clips, gauge pods, face plates, etc)
    Sooner or later both of these will be purchased; however, it’s a matter of what I’ll learn next (i.e. spend hours upon hours learning how to do it). Opinions? Thoughts? Off-color remarks?
    6,315
    I am would lean towards the welder, but the 3D printer may be handy.
    I know that helps
  3. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    If these are the only choices most definitely the welder
    • Agree Agree x 2
    • Like Like x 1
  4. 00Mini
    2,259
    My first choice would also be the welder.
  5. Dave.0
    MIG
    3D printer prices will keep falling in price.
  6. old81
    3D printers are evolving, some new models with great enhancements in 2020. My D-I-L is a designer, they just started a new company this month. So watch for new stuff ourt of Loveland.
    Go with the MIG and wait 6 to 12 months for the best in 3D.
    • Like Like x 3
    • Agree Agree x 2
  7. Skidmarks
    Skidmarks Active Member
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Welder, I didn't see Nik Blackhurst use a 3d printer.
    • Winner Winner x 2
    • Like Like x 1
    • Funny Funny x 1
  8. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Hi ho, hi ho, MiG welding I shall go. Grateful for all the input.
    Great to know the printers are in a functional leap cycle too. Def need to pause on that purchase.
    • Like Like x 2
    • Funny Funny x 1
  9. Minidave
    Not only that, but there are companies now that will print your stuff for you, so you don't have to learn CAD in order to print something.
    I use my MIG all the time, you just never know when you will need it for a project, big or small.
    Most of the plastic bits you need for a MINI/Mini are still available too....don't know about the Samurai....
    • Like Like x 3
    • Agree Agree x 2
  10. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Relatively expensive at the moment but I don’t “need” anything other than a few gauge pods.
    The printer was consider because I wanted one of the wind deflectors for my R59 which price about the same as a cheap end 3D printer to be used to make a mold for acrylic casting.
    The welder is for an exoskeleton. I could either pay someone $1500 to make one or spend $2000-$3000 (welder + materials + mistakes) to learn how to myself.
  11. Minidave
    Sometimes it's cheaper, better and the result comes quicker if you just hire the guy that knows how to build one, plus you'll need a big ass tubing bender and a notcher to build that...... can't wait to see the results. Good luck with the project!
    • Like Like x 1
    • Agree Agree x 1
  12. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    I know right! I may have someone build the cage to my spec but I’ll finish it off with building the roof rack.
    Having a solid project is necessary for the motivation & desire to truly learn how to weld properly.
    “Necessity is the mother of invention”
  13. Minidave
    You'll also learn how to grind welds then! :)
    My first project the welds were awful, I think I ground off more than I left but I learned - as you said. Best way to learn is to stick yourself in and go, but if you have someone who knows how at your elbow, you'll learn quicker and your welds will actually be strong. Post picks of your project so we can see what you're going to do!
    One thing I really recommend - buy a Mig with gas, don't use flux core - you're welds will be better and cleaner. Oh, and cheap Harbor Freight welders may work OK, but a name brand will have a much higher duty cycle (cheap welders are usually only 20%, good ones are closer to 90% ) and give cleaner, better welds with good penetration. You can buy a Lincoln for not a whole lot more than a cheap HF....and get a good auto darkening helmet too.
  14. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    I’m definitely going with MiG. A veteran buddy of my said I should do MiG since I’ll mostly be welding I’m the car & engine bay.
    Over the next few months I’ll be buying all the bits. I got gloves, need: {jacket, bin or shirt}, Blanket, magnets, welding table, hammer/chisel, brushes, welder (duh), etc. Then a few varying gauge steel scraps for practicing (pick a part)
    I’m thinking the Miller welding mask (not the helmet) since I’d be in the engine bay and undercarriage ... which appears to provide greater comfort and maneuverability. ... along with an acceptable welding cap for sweat (polka dots or flowers)
    I’d have purchased most of this but @MCS02 “made” me buy a Hotchkis rear sway bar for my mini.
    • Like Like x 2
    • Funny Funny x 1
  15. Minidave
    You don't need all that, chisels and hammers not needed with Mig if you use gas, the welds will be clean, the most you'll need is a wire brush.
    f course, it never hurts to suit up properly......
    • Like Like x 1
    • Agree Agree x 1
  16. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Humbly thank you. I hadn’t made the connection between the shielding gas & slag removal chisel/hammer.
