Brakes Wheels 2nd Gen Tires Lifespan of OEM rotors / pads
Discussion in '2nd Generation: 2007+ R55 through R61' started by Rixter, Jul 27, 2010.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Just curious, for street driving only, what kind of lifespan are folks getting out of their pads and rotors?
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  3. BThayer23
    40k for OEM
  4. cct1
    Saw this, and although it's off topic somewhat, I went back and counted rotors..
    My car has 19,000 miles on it. I'm on rotor set #7, lost count of pads.:D
    Virtually none of this abuse occurred on the street though.
  5. goaljnky
    3,105
    394
    I don't know. Sorry.
  6. Nathan
    [ame=http://www.youtube.com/watch?v=LZ0epRjfGLw]YouTube - Tootsie Pop[/ame]
  7. Minidave
    4,592
    The dealer replaced my front pads under warranty at 18K on my '09 Clubby, I didn't think they were down that far but what the heck, free pads! They did have 2 track days on them tho....
    On my '03 I was changing them about every 20-25K. But they also had some track days on them. I don't think I'm particularly hard on pads on the track tho, I'm not trying to be TTOTD.....
  8. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Thanks all. Except you Nate.
    CCT1 you must have a heck of a track budget :Thumbsup:
  9. cct1
    Well, I THINK I've got the setup that will allow a full year of abuse before needing new rotors, we'll see.
    Does add up though.
  10. lotsie
    stagehand/part time detailer
    Right here
    I motored 100 miles a day on bald a$$ prairie, and for the most part used the brakes very lightly, for the first 3 years I had Poco. Moved to the hills of Missouri, and had to change them out, at 85,000.
    I also got 7 years out of my OEM battery, and just did the front bushings at 108,000.
    Those are miles Rixter:Thumbsup:
    Mark
  11. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Mark
    Outstanding! I guess coasting to a stop really does help
  12. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    With a 40/60 Hwy/City mix of driving I'm looking at 30k miles for the fronts and 40k miles for the rears. No sign that I need to replace the rotors though...
  13. danf
    danf New Member
    Aug 30, 2009
    33
    I've got 33k on my car and I'm on my 3rd set.
  14. ZippyNH
    I've got about 50,000 on my 05 S....
    Still on my OEM rotors/pads on the front...
    The odd thing is I'm on my second set on the REAR!!:confused5:
    My car does sit quite a bit (in an airport parking lot)...and I think due to them not getting heated up, the salt/chemicals corroded the rotors on me...they stated to flake/crust around the edges...state inspection guy didn't like them....turned out the pads were about 90% worn....but my fronts were still at 60%:blush2: (two years ago).
    I guess I need to use my brakes more...or stop planning so far in advance!! The new rotors I put on are Zimmerman's....seem to be doing very nice.
    29-30.5 MPG doing highway driving at 72 MPG is not half bad on a tuned MINI....
  15. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    I've got a little over 44K. No track time but some aggressive amusement down the occasional crooked road if you can imagine.
    Well said, Nathan:Thumbsup:.
  16. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    The majority of the beginning of my cars life was spent on highways. Im up to 46K on stock everything. They feel and look as though they have plenty left too lol (knock on wood..my luck ill get a change pads light on the way home)
    Im also a coaster, and dont brake when I dont have to haha. Never downshift either
  17. Mr. Jim
    I've got 42,000 on mine, still the original jcw stuff, Dragon once, Blue Ridge a few, plus occasional auto-cross and lots of spritied driving. I will most likely do them up next spring with ss brake lines, new rotors and pads.
  18. danf
    danf New Member
    Aug 30, 2009
    33
    Sometimes the rears wear out first because of the emergency brake. After releasing it, the inside pad does not retract and gets more wear.
