Lifting the MINI
Discussion in 'MINI' started by genik, Mar 31, 2014.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    How can i lift the mini, simply, without any machines in order to replace oil or fix minor stuff underneath? Any DIY solutions?
    I just drink a few shots of Starbucks and use my arms. :lol:
    What do you mean no machines? Does that include a floor jack? If not just lift it with a jack by placing it under a jack point and pump the floor jack handle up and down to desired height is reached. If you get under the car use jack stands for safety unless you had the extra Starbucks and can bench press your car. :lol:
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    :D haha your funny and yes no floor jacks either!
  4. Dave.0
    You can use cinder blocks or a lot of bricks and some long 10x2's and build a set of ramps.
    I have also seen people pull over a pit and work from under the car.
  5. rkw
    rkw Well-Known Member
    443
    A pair of service ramps? Either a set built for the purpose or make something yourself.
  6. MCS02
    #6 MCS02, Mar 31, 2014
    Ok my real shade tree self is about to show through. Drive two wheels up on the curb, set the parking brake and put something behind the wheels so it can't roll.
    I've used this method when I was young. Just enough room to squeeze under.
  7. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Go to Wal Mart and but some rhino ramps
  8. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    If you build your own ramps be sure to video the whole thing. Reality TV pays big bucks for videos with surprises. Otherwise try following Blimey Cabrio's instructions on how to lift a MINI with a 2X4.
    BlimeyCabrio » 2007 » April
  9. Firebro17
    I sense a power tool accident on the horizon.
  10. Metalman
    No tools needed.... But it does require a second MINI...
    Just remember on which side the drain hole is located...:D
  11. MCS02
    Just wondering what's the reason for the question? You can get a small jack for not much money. You need to be careful. If you don't have the correct tools don't do the job.
    Never get under a car unless it's on ramps or jack stands.
