1st Gen R53 Cooper S Limp Mode
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by broncoupe, Apr 17, 2016.
  1. broncoupe
    broncoupe New Member
    Apr 17, 2016
    11
    Have an 02 MCS does anyone know would a ABS fault cause the the EML to come on and the car to go to Limp mode
    thanks
  2. BlimeyCabrio
    I haven't seen an ABS fault do that. Why do you suspect the ABS? Any other symptoms?
  3. ZippyNH
    Think you need too looks elsewhere for the fault causing the limp mode....
    Limp mode usually comes from an engine management issue....the engine computer says it doesn't understand... And limpmode keeps the engine running enough to get to a safe spot to shutdown....
    Bad abs sensors, or a computer can set a check engine light,or a code...but pretty sure no triggering of limp mode.
  4. broncoupe
    Apr 17, 2016
    11
    all my problems started at once
    havnt driven it since oct 15 still love but need to sort it now
    Had a couple of instances of EML light plus limp but they cleared on restart so did nothing
    then had what they call trifecta
    so
    ABS light
    tpms light
    traction light
    but also
    EML and limp mode `
    Read codes and they were all communication faults stored in ABS Ecu
    so i thought maybe ABS not communicating but the ECU companies that do repairs thought unit was ok
    thought it might be an ABS sensor so was trying to replace passenger front when it snapped off.
    i was trying to find out if this could be linked or if 2 separate faults
    the EML is what i want to sort first :mad2::mad2:
  5. BlimeyCabrio
    The EML is probably not the wheel speed sensor / ABS. Trifecta is probably wheel speed sensor, as you suggest, rarely do the ABS modules cause any problems.
    For the limp mode, most likely culprit is crank pulley failing, it's a two part pulley with rubber connecting the halves. When they get old the rubber tears and the pulley can turn somewhat independently, which causes supercharger and alternator to not turn at the expected speed, and the ECU complains with EML and limp.
    BUT there are quite a few other things that can cause limp mode. Someone who knows MINIs really needs to inspect carefully to further diagnose.
  6. broncoupe
    Apr 17, 2016
    11
    Funny that had a new alternator last year
    Can you see if the pulley is breaking up?, also seems it could be Throttle or engine loom just suggest away
    broncoupe
  7. broncoupe
    Apr 17, 2016
    11
    sorry had a new CPS sensor that failed just after Clutch changed
  8. BlimeyCabrio
    Someone with a proper BMW-aware scan tool should be able to pinpoint it, quickly.
  9. broncoupe
    Apr 17, 2016
    11
    I have an autel scan tool and also Delphi software Ebay
    Copy there great for fault codes but my codes are
    5E1A
    5E19
    P1570:mad:
  10. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    limp mode can be caused by anything. On my Tundra I it was a silly pair pump needed for cold starts only. I can see how a manufacturer could argue that a bad ABS unit is reason to slow you down until fixed. Actually, makes more sense than the silly air pump in my truck that does nothing more than add fresh air to the same stinky exhaust the truck has without it, just creating (cheating) to get you better parts per million in a test. Bad ABS system could actually cause injury and law suit/
    Go get a generic code scanner from O'Reilleys or similar car parts store to get the codes. Have you tried resetting with battery disconnect reconnect?
  11. broncoupe
    Apr 17, 2016
    11
    Code codes got software what im trying to do is pin down the problem area / areas
  12. broncoupe
    Apr 17, 2016
    11
    Whats confusing is you get trifecta lights because of ABS fault thats ok i get that
    you then drive a few feet forward and the EML light comes on and LIMP mode
    I can understand why no one else has had this problem
  13. BlimeyCabrio
    And what I'm saying is, every time I've seen limp mode, there have been OTHER errors reported by the DME or other modules, that explained it. These don't usually appear as OBD-II codes. So the BMW-specific scan tools can interrogate ALL the modules on the car and report exactly what they're seeing. Maybe the Autel can go that deep, I don't know.
  14. Metalman
    Sometimes I go into limp mode....:eek:
  15. Dave.0
    They have pills for that now. :ihih::lol:
  16. Metalman
    Wut.... They have pills now that fix bad ankles?:D
  17. cct1
    Wouldn't that be cankles?
  18. Dave.0
    Yup they will make them stiff for 4 hours. :lol:
  19. ZippyNH
    Just remember too seek "professional help" ......always makes me wonder what type of a pro!!:lol:
    And to the OP...You have TWO or more issues....
    One is the abs/wheel speed sensors issues....
    Another is a an engine issue....you just happen to have them at the same time....but fact is a car with a failed wheel speed sensors, pump, etc is drivable...you can yank the fuse for the system....heck...folks have done it for track cars....the "trifecta" is annoying....but more is going on.
  20. broncoupe
    Apr 17, 2016
    11
    This is the info i have been looking for so on track cars by pulling the fuse they dont have traction control
