2nd Gen R55 Clubman Look what Gimli got
Discussion in '2nd Generation: 2007+ R55 through R61' started by lotsie, Aug 6, 2010.
  1. lotsie
    stagehand/part time detailer
    Right here
    We just had this installed on Gimli, our Clubman.
    Mark
    Congrats on the new badge. :ihih:
  3. Justa Jim
    I didn't know you had a JCW! :Thumbsup:
    I like the name.
  4. goaljnky
    3,105
    394
    Sweet, although I still want to know why the JCW badge has a surf board in it.
  5. lotsie
    Right here
    We left the dealer, and I was behind in Poco, and I saw Lois blew that other eyeball right off:lol:
    Mark
  6. lotsie
    Right here
    We didn't, but we do now:D
    Mark
  7. Mr. Jim
    Congrats!
  8. Metalman
  9. Metalman
    Just a thought. Did you remove the bazillion layers of Prima under that new badge. They are crazy expensive to replace if it falls off.
  10. lotsie
    Right here
    Well the JCW is great, but guess what, the bloody clutch went out coming home from dinner tonight:mad2: Thought the revs were climbing WAY faster than the car was reacting to it, smelt clutch burning, going up a slight incline, it just would not climb, and within a few hundred feet we were coasting to a stop. Dark road, just after a few curves, not a good place to be. We were just outside a park and a Ranger sat behind us until the wrecker can, nearly 2 hours later:rolleyes5:
    Going to bed now:(
    Mark
  11. MinixB
    MinixB Member
    Jul 14, 2009
    269
    14
    Female
    Graphic Account Specialist
    Kansas City, MO
    Oh no!! Are you going to be able to get it fixed for MTTS? :(
  12. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    Mark,
    Not sure if it matters to you but (at least on coupes) when a JCW Stage I kit is installed, the Cooper S emblem is taken off and the JCW emblem is installed by itself.
    The only thing differentiating it then from a factory JCW is the Stage I JCW emblem is on the opposite side.
    Not sure that works for clubmans but I was told that by the tech that installs JCW Stage I kits that did mine on my '08.
    Food for thought...
    Mark
  13. lotsie
    Right here
    I would doubt it. Dealer is closed till Monday, and even if they had a new one, from what I have read it takes 12 or so hours. We are leaving Tuesday morning.
    So the plan is, be at the dealer before the crack of the first Sparrow fart, deal with the paper work, get a loaner, and drive it to MITM. If for some reason that does not work out, we will take Poco, the 03 justa. I know they have Clubman loaners, but a coupe would work also, just the dogs would be a bit cramped.
    Mark
  14. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Oh man that sucks so much! Congrats on the JCW though!
  15. lotsie
    Right here
    I'm now starting to wonder if the fact the starter went bad, grinding away on the flywheel if that may have had anything to do with it.
    It happened real fast, with no problems before yesterday. I also wonder if the extra HP just sped up the problem. I'm happy:rolleyes5: it happened here though, and not on some mountain pass in Colorado, or in the middle of Kansas, with 2 dogs, our stuff, and temps that look like they will be close to 100F.
  16. Nathan
    Sorry to hear of your troubles. Glad it was before y'all left for the journey tho. Book says 12 hrs for a clutch, a tech worth his salt can do it in less. I'd cajole the dealer into getting it done on Monday reminding them you are headed to MTTS / MITM and all the goodwill you can spread about what a wonderful job the dealer did getting you off in time.
    I'll wave as I zip through St Louis tomorrow on the way to Indy.
  17. lotsie
    Right here
    I'm sure they will do all they can for us, I think they like us:lol: Even if we did not get it back till midday Tuesday, we could still make our planned overnight stop in Colby Kansas. We would likely motor with zinful then.
    Mark
  18. Metalman
    Sorry to hear about your troubles. Talk the dealer into a JCW Clubman and put all the wear and tear on the loaner.:Thumbsup:
  19. lotsie
    Right here
    If your coming up I-44 and need a quick pee break, we a 2 minutes from it.
    Mark
