Looking at a 2003 Cooper S today
Discussion in 'Starting Line - New Member Introductions' started by xxerniexx, Feb 1, 2015.
  1. xxerniexx
    xxerniexx New Member
    Feb 1, 2015
    Good morning all,
    My name is Ernie and I'm not a Mini owner yet! I am going to be looking at an '03 Cooper S later today with 130+ miles on it, owner says other than the A/C needing to be charged, the car is perfect.
    My question is what kind of things should I be looking for other than the A/C that might spell disaster for me later on?
    Thanks
    Ernie in South Florida
    Look for a few things..
    Strut towers. they should be level the studs all pointing straight up. An easy fix though.
    Coolant tank, make sure is not split. Recommend replace soon with non-OEM if not already done.
    Lower Control Arm bushings, check when last serviced and what brand was used.
    MotoringFile has a really good Buyers Guide for the R53. MotoringFile » MINI R50/R53 Buyers Guide So good that I see no reason to write one for the M/A library.
  3. Dave.0
    Welcome to M\A the FUN MINI site. :Thumbsup:
    Things I would check are:
    1# ask if it has been modded...Pully, tuned and listen to any other information they offer.
    The oil , let it run and listen to the motor.
    Test the radio then turn it off and listen to the car.
    Look under the car and check the exhaust for rust. "Mufflers".
    Take if for a test drive and find a parking lot and do some figure 8 and listen to the suspension. This will let you here I'd the lower control arm bushings are shot and you will also hear everything else.
    Above all else get the service history with that mileage and find out if it has been hit.
    Run a car fax report for what it's worth just to be safe.
    Now this is the hardest part, DO NOT FALL IN LOVE WITH IT. That will cause you to buy a poor high milage car with many hidden problems that you hate later.
    Remember you can always find another one with lower milage and in better shape because they are available.
  4. xxerniexx
    Feb 1, 2015
    Dave, thanks for the welcome and advice! Went and saw the car looked great this was my fourth to see this weekend. Mechanically, minus the a/c, is great. Shifts really smooth, radio on and off was good, no rust on the mufflers, no noise in the hard turns. Drove home, about a 40 minute drive, was great no overheating temp stayed right in the middle. Again thanks
    Ernie
    2003 MINI Cooper S
  5. Firebro17
    Best of great times to you and your new ride!
  6. Dave.0
    Looks good does it have any mods at all or was owned by a little old lady that never did anything to it but drive to church on Sunday?
  7. wmwny
    4,048
    2,246
    Welcome to M/A!
  8. xxerniexx
    Feb 1, 2015
    Thanks for all the welcomes!
    Bone stock! First thing to do it change the oil and then start looking at all these mods I see around here.
    There is a small tear in the drivers seat I need to address and the sill plates are buggered up but that should be easy.
    Welcome to M/A
    My advice is before doing any mods catch up on the maintenance. Changing the oil is a good place to start. Add to that change the brake fluid, flush the coolant & change the trans oil. Enjoy your new MINI.
  10. MCS02
    6,278
    Welcome to MA! Nice ride!
  11. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    Might want to get those lights cleaned up!
  12. MCS02
    6,278
    I use a light rubbing compound on my lights to keep them clear. If there too bad you may need to get out the sandpaper.
  13. mrntd
    Welcome Aboard!
    Great looking new ride!
  14. 00Mini
    2,228
    Great looking 03 and Welcome to Motoring Alliance the only MINI forum you'll ever need !!
  15. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
