Brakes Wheels 2nd Gen Tires Looking for new wheels
Discussion in '2nd Generation: 2007+ R55 through R61' started by rum4, Apr 15, 2012.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Looking at putting these wheels on my White Silver Clubman? What do yall think? Also what exactly are tuner lugs?
    Good looking wheel for the most part. Personally I am not a fan of the 8 hole multi-fit centers. I tend to always pick the wrong bolt circle when mounting them.
    Will there be other accents on the MINI that will pickup the coppery orange of the rim sections?
    Not a fan of black wheels, but I like those with the orange accent, not that it matters. What you like does. How much do those wheels weigh in at? Unsprung weight does matter.
    Tuner lugs are something like spline drives. Not sure you would need to uses those. On the Panasports wheels on my Miata I had to use them due to clearance issues with the stock lug nuts.
  4. Metalman
    Match your mirror caps to the metallic orange and you'll be golden....:Thumbsup:
  5. ScottinBend
    Tuner bolts/nuts are usually a smaller diameter part that the wheel will need because of clearance issues. I have to run them on my wheels also as the stock 17mm nut will not fit.
    And I love black wheels.....check out my garage.
  6. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    I think they would look pretty sweet. Also never a fan of dual-drilled rims, but that is still a nice looking wheel
  7. rum4
    4,568
    1,475
    SC
    Would love to find some used good wheels that we're 17x7/7.5/8 but new they are way to expensive. I keep hearing about how "rep" wheels are bad and cheap wheels are no good. The so called good wheels are expensive.
  8. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Be careful of rims requiring tuner lugs! Mid 2006 and newer MINIs have an odd size lug bolt (M14x1.25) that no one makes in a slim tuner lug . You would have to get a stud conversion kit.
  9. rum4
    4,568
    1,475
    SC
    ok thanks
  10. Soap
    Soap New Member
    Mar 18, 2012
    44
    CFO of Elgersma Inc, my 8month old is the CEO!
    I like the wheels and think the orangish strip is a nice little touch.
    I had some TSW wheels similar to those in style and they are a pain to clean. just IMHO.
  11. rum4
    4,568
    1,475
    SC
    thanks, looks like the search continues:)
