2nd Gen R56 Cooper S Loose Hubs?
Discussion in '2nd Generation: 2007+ R55 through R61' started by KittyMini, Aug 3, 2011.
  1. KittyMini
    KittyMini Club Coordinator
    1,183
    I mentioned this in the "What did you do with your MINI today" thread, but I'm still a little perplexed.
    My hub was found loose the other day..... anyone else stumble on this? Is it a common thing? :confused5:
  2. BThayer23
    Wheel bearings can wear out. Hitting a curb or a pothole hard can deform one of the ball bearings and the hub will wear out pretty quickly. On a lift, the mechanic will walk around and wiggle the wheels. There should be no play in both the suspension linkage and the wheel hub. Front hubs are more expensive and more difficult to replace because they're connected to the axles; rear hubs are easy and cheaper.
  3. KittyMini
    1,183
    As far as I know, a simple tightening of the huge nut on the end did the trick. Hopefully it stays tight :eek6:
  4. BThayer23
    Oh. Yeah, that's a big nut. Glad they fixed it.
  5. KittyMini
    1,183
    The hubby did...... but I don't understand why it was loose in the first place :confused5:
  6. Nathan
    I thought the hub has a castellated nut.
  7. KittyMini
    1,183
    Just looked like a big nut to me. There was nothing to prevent it from just working it's way all the way off.
  8. Metalman
    #8 Metalman, Aug 3, 2011
    The shaft that the "Big Azz" nut was on should have a "kerf" cut through the threads. The nut itself has a thin rim that is supposed to be deformed into this kerf after the proper tightening of the B/A nut. This deformation prevents the B/A nut from working itself off. You should make sure this was done properly....
    This is a similar nut that I speak of....
  9. KittyMini
    1,183
    Just sent this info to the hubby to see if he noticed anything.
    Might have to swing by the dealership?
    Oh, and there was a dent in the collar around it???????
  10. Metalman
    The dent was in the thin collar of the nut.... correct?
  11. BThayer23
    P/N 31106773005 Hex nut with flange, M22x1.5 - ZNS3
    Yup, just a hex nut. Did the hubby add loctite to the nut?
  12. KittyMini
    1,183
    LOL- nope.
    I called the dealership. They were alarmed and told me to bring it in immediately.
    So I'm going to have them check it out tomorrow morning. :crazy:
  13. Metalman
    Good... Give us a report when finished.
  14. Justa Jim
    Yes, please do. This has had my full attention, every since you posted. I can not believe that something like that has no locking device. :eek6:
  15. KittyMini
    1,183
    Oh I will- the service dude freaked out and told me to come in immediately. I was like, "oh, ok, but I've been driving around all week like this after the hubby tightened it".
    He must think I'm an idiot now... hell, maybe I am :eek:ut:
    I can see how he might be a little worried, but if he was really worried he'd tell you to have it flatbed over.
  17. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Couple of points:
    1) That style nut is VEEEEEEEEEEEEEEEEEEEEEEEEEEEEERY common, and can really be found on almost every car made today. Most cars made today use a sealed bearing within the whole hub assembly. This is why the parts are most costly in the first place, but also why there is next to zero call for wheel bearings to be packed. With that, the hub bolt can be torqued very tight (80 ft/lb) . W/ older style wheel bearings, you did NOT torque much (13 ft/lb), and they used a "castle-nut" to prevent the nut from backing out. The current design is MUCH safer and less maintenance.
    2) That nut only holds the axle in place, not the hub.
    3) The hub is held in place by four bolts on the back-side of the knuckle. If the hub was really what was loose, then those four bolts are the culprits.
    4) DO NOT PUT LOCK-TITE ON THAT NUT. There is zero need for it, and will only cause issue later.
    I hope the dealer is able to get you going right.
  18. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    sounds painfull:eek6:
  19. HRM
    HRM New Member
    Mar 16, 2011
    74
    10
    As people mentioned already, to lock the nut in place you take a punch, line up to the cut out groove on the axle shaft, and whack it with a hammer to dent the top of the nut. The dent should now go into the groove in the shaft and prevent the nut from coming loose. If the last guy who worked on it didn't get this part right, the nut could spin loose. If it was whacked properly, then any play would be worrisome and come from somewhere else.
  20. KittyMini
    1,183
    Not much of an update:
    Dropped Artemis off this morning.
    Haven't gotten a call yet with someone screaming at the other end, "WTF did you do?!?!?!?" :lol:
    Stay tuned.....
