2nd Gen R56 Cooper S Lost Power Autocrossing Today
Discussion in '2nd Generation: 2007+ R55 through R61' started by emptyo, May 25, 2014.
  1. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    I did a PCA Autocross event today (12 runs) and after run #9 I lost serious power. It was almost as if my turbo didn't work anymore...I just lost all my boost. Could I have popped a hose off or something?
    I'm new to turbos, so I'd love some help troubleshooting.
    Thanks!
    m
    I can't help but I'll give you a bump. Someone will be along that can help.
  3. Dave.0
    Heat soak? I have no idea. I am a Supercharger and Methanol guy and I don't have heat or carbon issues.
  4. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    Lol...thanks for posting that you DON'T know. ;)
  5. Metalman
    You probably didn't pop a hose off because it would have generated an error code...
    You may have torn the bladder in the blowoff recirculating valve in the turbo.... But that should have generated an error code.....
    Soooo.... Lost power but no codes thrown???
  6. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    How do I check if there are codes?
  7. MCS02
    If you don't have a OBDII reader run it to Autozone they can read it for you.
  8. DneprDave
    Or buy an OBD2 reader, they aren't that expensive and are a very useful diagnostic tool.
    Dave
  9. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    UPDATE: Checked under the hood. Cold air intake was completely disconnected. Friend brought over OBD II reader. Was throwing a code that I was running lean. (Presumably because of the air intake). Cleared the code, hopeful that would bring back the boost, to no avail.
    No more codes, but I'm only getting 2-3 psi of boost under full load.
    Not sure where to turn next.
  10. tallguymini
    tallguymini New Member
    Jan 6, 2014
    Your in limp mode
  11. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    Yep, definitely in limp mode. Need Viagra.
  12. Metalman
    There are all kinds of fittings / clip rings / hose clamps for the rigid and flexible hoses from the turbo to the intake manifold..... Any one of them could possibly have come loose.... There is also an area back by the firewall (passenger side of the engine) that can rub and wear a hole in the rubber hose...
    Sounds like you are getting some pressure.... Maybe a small hole that blew out on your aggressive track day....
    Don't overlook the possibility of the diverter valve on the turbo getting ruptured... It sounds like this is your problem... Unfortunately you need to take it apart to verify this.. Follow the hoses from the turbo first.... Make sure everything is tight... Still have the problem... Then go for the diverter valve... They go for something like $75 if I remember...:Thumbsup:
    Read here...http://www.motoringalliance.com/forums/cooper-s/12391-blow-off-valve-issues.html
    Happy Hunting...:D
  13. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    Alright, thanks for the heads up! I'll check it out.
  14. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    Update!
    My cat had separated from the turbo, due to a really shoddy re-install of the stock muffler by the PO. The cold air intake tube also was completely disconnected. Needless to say, there were air leaks all over the place. I also had the valves walnut blasted, and the ECU updated to current firmware.
    Check engine light is off, and the car is RIPPING once again!
    Now...time for that LSD...
  15. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    double post...sorry.
  16. Metalman
    I'm surprised you didn't report an exhaust leak.... That would have been a strong indicator in helping to diagnose your problem...
  17. MCS02
    Hay man don't do LSD and drive.
    Just say in :devil:
    [ame="http://m.youtube.com/watch?v=ZqXmBy1_qOQ"]http://m.youtube.com/watch?v=ZqXmBy1_qOQ[/ame]
  18. emptyo
    emptyo Member
    May 6, 2014
    46
    35
    Podcaster
    San Diego
    Well...I didn't know I had one until we did a smoke test. But now I do. :) Now the car is ripping!
