1st Gen R53 Cooper S Loud squeal!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Newbie6, Jun 22, 2017.
  1. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Hey everyone just wanted to know if this would be the idler pulley, tensioner or belt but at idle it doesn't make noise but giving it gas it starts...I have a video of this but for some reason I can't upload it. I just want to make sure it is this and not the bearings in the supercharger or something before I order a new idle pulley and tensioner with new belt.
  2. wmwny
    4,048
    2,246
    Welcome to M/A!:Thumbsup:
    Someone with more knowledge than I will be around soon to offer help with your squealing problem.
    Hard to tell without hearing it, but I'd suspect the belt, tensioner & idler pulley in that order. How many miles on your MINI? Have you ever replaced those components?
  4. MCS02
    Welcome to MA! The SC makes more of a rattle or grinding noise. I agree with Crashton. If its been a while sense you changed the belt it needs to be done anyway. Do you have a stock SC pulley? If not make sure and get the proper belt for you SC pulley size. Also it could be bad alternator bearings.
  5. Dave.0
    Pop the hood and make sure you don't have a little piggy under your hood.
    Old belt, idler pulley and new tensioner should fix the problem. Amazon is your friend for a new tensioner over the $225.00 dealership one. They are the same part.
    Tensioner : https://www.amazon.com/ACDelco-38404-Professional-Automatic-Tensioner/dp/B001KSDZOY/ref=pd_bxgy_263_2?_encoding=UTF8&pd_rd_i=B001KSDZOY&pd_rd_r=H6RJAVT4YZ94W3P30QKF&pd_rd_w=MfI8U&pd_rd_wg=Lj0nA&psc=1&refRID=H6RJAVT4YZ94W3P30QKF
    Or this one: (Same part) https://www.amazon.com/Gates-38404-Belt-Tensioner/dp/B001KQJRDO/ref=pd_sim_263_4?_encoding=UTF8&pd_rd_i=B001KQJRDO&pd_rd_r=YXN8Y34PNDPG10G3BG8A&pd_rd_w=EM9IE&pd_rd_wg=S4WKg&psc=1&refRID=YXN8Y34PNDPG10G3BG8A
    Idle pulley : https://www.amazon.com/ACDelco-36168-Professional-Pulley-Shield/dp/B001FJI2VO/ref=pd_bxgy_263_2?_encoding=UTF8&pd_rd_i=B001FJI2VO&pd_rd_r=ZRKZV7ZRDY7S4M2NSDWW&pd_rd_w=qnV1o&pd_rd_wg=Vfd7N&psc=1&refRID=ZRKZV7ZRDY7S4M2NSDWW
    15% pulley belt: Gates K060535 Multi V-Groove Belt
    https://www.amazon.com/Gates-K060535-Multi-V-Groove-Belt/dp/B000C2SIXC/ref=pd_bxgy_263_3?_encoding=UTF8&pd_rd_i=B000C2SIXC&pd_rd_r=CSGGRH8G364P67TT3T8H&pd_rd_w=DpjAs&pd_rd_wg=WT6rt&psc=1&refRID=CSGGRH8G364P67TT3T8H
    17% pulley belt: Gates K060532 Multi V-Groove Belt
    https://www.amazon.com/Gates-K060532-Multi-V-Groove-Belt/dp/B000C2YCIC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1498268369&sr=1-1&keywords=Gates+K060532
    If you have high mileage 80K plus your OEM crank damper may be starting to fail which happens to everybody.
    Buy the ATI damper and never have to worry about it again. Buy the right one from the guys at Detroit Tuned.
    http://www.detroittuned.com/ati-super-damper/
  6. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Awesome thank you guys, I haven't changed it since owning my car but I already ordered the new tensioner and idler pulley and stock belt since my car is all stock minus the cold air intake and my cat back exhaust
  7. MCS02
    Time for a 15% pulley!!
  8. Newbie6
    Newbie6 Member
    Apr 7, 2015
    Ha ha yea I've thought about it but I'm just keeping my car as stock as possible and just fixing everything first I've already went way overboard on my mustang and Audi
  9. Firebro17
    Does it sound like a pig?!
