Low oil pressure at idle once car warm up
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Sidewalk Girl, Jun 17, 2023.
  1. Sidewalk Girl
    Sidewalk Girl New Member
    Jun 2, 2023
    16
    Female
    #1 Sidewalk Girl, Jun 17, 2023
    I have been troubleshooting this problem for a while. I changed the oil pressure switch no difference. Then I change the plunger valve the filter to OEM and oil, still the same problem. Now I just changed the complete oil filter housing assembly and still have the same problem. I am at a lose for what it could be as the oil pressure when driving is good. HELP
    I think there must be a way to connect a real oil pressure gauge & get a reading. At this point you are chasing your tail. Hopefully someone chimes in here to tell you how to do that, as I don't know how. Good luck...
  3. DneprDave
    You didn't say what year and model MINI you have.
    Cravenspeed has gauges and adaptors. That's where I would start.
  4. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    Sorry its a 2008 S convertible Sidewalk edition
  5. checkers
    checkers Well-Known Member
    Jun 11, 2009
    4,338
    994
    Modesto, Ca
    What is your oil pressure at idle and when driving?
  6. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    Here is where the oil pressure is at startup and when driving on freeway.
  7. MCS02
    6,322
    As they have said, a mechanical gage is the only way to verify your oil pressure gauge is correct. Does your oil pressures light come on at idle? If not you are probably ok. How many miles are on the car?
  8. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    #8 Sidewalk Girl, Jun 17, 2023
    Yes the red light comes on only after driving for about 10 min at idle. Car has 80,000 miles
  9. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    The drama never finishes with this car. Now the dipstick broke. Went to check the oil and the last 6-10 inches of the dipstick was missing. I guess I will need to drop the oil pan which from what I've seen is a pain in the ass.
  10. 00Mini
    2,266
    Or disassemble the front end and remove the dipstick tube which hopefully the remainder of the dipstick will still be in. .
  11. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    That's too much work. I saw a video where they removed the oil pan without removing the front nose. Apparently it's getting the AC compressor out of the way to remove the last 2 bolts.
  12. 00Mini
    2,266
    Keep us informed on how you make out.
  13. MCS02
    6,322
    @Sidewalk Girl The up side is you can check the oil pump and pickup up when you’re in there and replace to oil pan gasket. The front of the car is not too hard to do. I got to where I could have it off in about 20 min. Take a good look at the oil pressure switch it may need replacing. Read what Detroit Tuned has to say
    https://www.detroittuned.com/mini-oil-pressure-switch-g1/
    that may be your fix.
    On my R58 when the dipstick broke I replaced it with this one
    https://www.detroittuned.com/craven-speed-oil-dipstick-gen-1/
    It’s a bit like handling a snake when you check your oil but it won’t brake agin.
    I doubt there is anything wrong with the oil pump or screen.
  14. MCS02
    6,322
    Sorry I am not much help lately, I am on the road and the few days at home I am catching up. That should end soon.
  15. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    I changed the oil pressure switch and the new oil filter housing also had a new one. I'm thinking there it smug in the oil pan and oil pump screen is dirty or has the dipstick that broke off causing the problem.
  16. MCS02
    6,322
    I doubt the dipstick is the problem. With synthetic oil it would be quite the feat to get sludge in the oil pan. Worn main bearings could cause low oil pressure at idle but I don’t think that is the problem the car only has 80k on it. The oil pump could need replacing. Getting a mechanical gage reading would help know if you really have an oil pressure problem.
    I think you said you are using the oem filter? If not try that. I know you got a new oil filter housing but just to make sure something is not missed. Is the spring still in the bottom?
    • Informative Informative x 1
  17. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    Yes both the spring and plunger were in the new oil filter housing. It's a new OEM oil filter housing. I have to remove the oil pan to get the tip of the dipstick out anyway so I will also get a chance to see if the pan and screen have any obstruction. I'm also planning on checking oil pressure manually.
  18. MCS02
    6,322
    Good luck. I don’t think I have heard of an oil pump going out on a Gen 1 car…..but maybe.
  19. 00Mini
    2,266
    I missed this post but I had an oil pressure switch switch let loose on a Dodge Ramcharger and fortunately I was only a hundred yards from work and I was able repair it with no problems. You also were spot on with the Cravenspeed dip stick.
  20. Sidewalk Girl
    Jun 2, 2023
    16
    Female
    I finally got it fixed. I took out the BCM out and cleaned the entire circuit board with contact cleaner and reinstalled it. Problem went away and has been fine for over a month.
