2nd Gen R56 Cooper S Lowering springs and BOVs
Discussion in '2nd Generation: 2007+ R55 through R61' started by aoifemal1, Jan 4, 2015.
  1. aoifemal1
    aoifemal1 New Member
    Feb 10, 2014
    Hello,
    two questions:
    I am dying to lower my mini, but don't have alot to spend. Of course ideally i would prefer coilovers but dont think that can happen at the moment. Any recommendations for lowering springs, or am i just wasting my time?
    My second question is, if anyone knows of any affordable BOVs that function well
    Thanks!
    What are you going after. Looks or handling? If you want it to Handel better I would get a rear sway bar first. Then some good struts and springs. I have Eiboch springs and Koni Yellows. Next I would get adjustable camber plates and adjustable rear control arms
    What year and kind of Mini?
  3. Dave.0
    Welcome to M\A but our crystal ball is broken. :lol: Could you please tell us about your car and what you are looking to do.
  4. aoifemal1
    Feb 10, 2014
    ive got a 2007 cooper s. im going for looks mainly but i am always throwing my mini around corners so kind of have to go for both!
  5. Stefanie
    Stefanie Well-Known Member
    May 8, 2014
    545
    804
    Sacramento, CA
    If coilovers are ultimately what you want, I'd suggest just saving up longer for those and getting something you're happy with. I know of a couple R56 guys in my area who put lowering springs on their stock shocks/struts and got a ride that was a little too..."bouncy"...so they ended up buying new shocks or coilovers anyway.
    I followed the advice of a bunch of people on these forums and put Koni Yellows and Swift Spec-R springs on my Mini...gave someone a ride last week and he commented that my car "sucks the ground." I'm taking it as a compliment...hehe. ;)
  6. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    NM Engineering
    I have NM engineering springs with the stock dampers and it lowered my car 1.5 inches and rides better than the stock sport suspension. $250 installed here in So.Ca.
  7. Dave.0
  8. nkfry
    nkfry New Member
    Roseville, MI
    As other have said, and Dave clarified on; if you are wanting coil overs save up and go right to them, but the biggest thing is to spend the money, cheap coilovers are just that. It also depends on what exactly you want from the car, do you plan on tracking the car, DD, road warrior, is ride quality an issue, and so on.
    As for BOVs, the Forge unit is the only valve we install on customer cars, there are eBay options, but the fact of quality per $$ spent comes into play again. If looks are truly what you are looking for I would recommend a cold air intake, such as DDM Works, or AEM, you will add a touch of class to the engine bay as well as getting audible boost recirc when letting off the throttle.
    DDM Works Street Intake
    DDM Works Race Intake
    AEM Race Intake
    Forge Blow Off Valve
  9. aoifemal1
    Feb 10, 2014
    On to the next question. I have realized I am not gonna have the money for the type of coil overs that I'd like to I have decided to choose a different route. I am looking at the forge blow off valve. I have heard that they do not make much noise, which is what I want. Does anyone have a forge bov that would like to weigh in?
    Forge Blow off Valve - Way Motor Works
  10. David Mc
    David Mc New Member
    Apr 19, 2015
    16
  11. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    David Mc - the GFB DV+ won't work on the N14 engine, unfortunately.
    FWIW, stick with the stock diverter valve - these engines perform better when you keep the air in the engine instead of venting it to the atmosphere.
  12. Zapski
    If you're looking to have a louder BOV, you could change your intake out. You'll hear it breathe properly. I've got an Alta intake, and you can hear every breath she takes pretty clearly.
    Also I'm thinking of replacing the sway bar links in mine, the OEM ones look like pencils. Seems for stiffer handling that not having skinny bendy bits attached to the sway bar is a good way to start.
  13. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    The OE sway links are prone to failure anyway - they'll start clunking after 40-50k.
