MADNESS Autoworks 1967 Morris Mini Woody Wagon
Discussion in 'Classic Mini' started by MADNESS Autoworks, Feb 23, 2016.
  1. MADNESS Autoworks
    67
    Here at MADNESS Autoworks, we love creating unique projects with unique cars. We are building a performance based Morris Mini Woody Wagon here at our shop, designed to be a car to take out on Auto X and other light tracks days to have lots of fun in!
    Here are some images highlighting our build!
    The doors getting filed down for the panels.
    The heart and soul of the Woody Wagon; Honda B16 motor Turbocharged with a Turbo By Garrett GTX3067R. Looking to push out close to 500 HP!
    Big thank you to Turbo By Garrett for supporting our project with an agressive GTX-R Turbocharger!
    Steering column and wheel installed earlier this week.
    After getting sanded down by hand and bathed in acid, we are set for paint after some other components come together.
    Stay tuned for more updates as we get closer and closer to completing a unique blend of performance and Classic Mini!
  2. MADNESS Autoworks
    67
    Some more images!
  3. MADNESS Autoworks
    67
    We replaced the rear sliding windows with a sheet of metal with our company logo engraved. A colorful display of LED lights brings the logo alive!
    A few more adjustments to the Magnaflow Exhaust being done.
    We chose the American Muscle Collection to really tie in the classic steam punk vibe. Huge thanks to Auto Meter for supporting our build!
    Close up of a gauge.
    We have lowered the Mini to give it an aggressive stance look and feel. We have also replaced the floor and coated the interior with Lizard Skin. Looking forward to getting the seats in, which will be upholstered with brown leather.
    Big thank you to Our sponsors Turbo By Garrett and Auto Meter for support with our project.
  4. MADNESS Autoworks
    67
  5. MADNESS Autoworks
    67
  6. MADNESS Autoworks
    67
    Some images looking more finished up. :)
  7. MADNESS Autoworks
    67
    A couple more pictures..
    Here's some info on the Mini as well:
    Engine:
    Honda B16 w/ Eagle Rods, JE Pistons, CTR Cams, ACL Race Bearings, Ported 74MM Throttle Body, Hondata S3 Engine Management, Custom Turbo Manifold, Custom Charge Pipes, MIL Spec Wire Harness, RC 900cc injectors, AEM Fuel Rail & Regulator, Garrett GTX28R Turbo, TIAL 45mm Wastegate, Greddy Type RS BOV, WALBRO 485 FP, Custom Intercooler
    Transmission:
    VW Type 2 Bus built by Wright, 4.57 Ring & Pinion, Phoenix Gear Set, Supper Diff, Case Gussets, Chromeoly 930 CV Flages, Custom Engine Adapter Plate w/ Stage 4 Clutch, Hydraullic Release Bearing
    Suspension:
    Rear - Ladderbar Design w/ Coilovers
    Front - Custom Hybrid Setup w/ Honda Spindles mated to a reinforced classic mini suspension
    Body:
    Original 1967 Wood Kit, Custom Roll Cage, Original body reinforced to handle the added power, close to 50/50 weight distribution
    1,300 lbs w/ over 500 HP!
  8. Minidave
    4,594
    OK, I have a couple of questions - first of all though very interesting build!
    1) why did you put all the instruments to the left when the driver sits right?
    2) can you turn the front wheels more than a few degrees given their size and that stance?
    3) How far will the front end come off the ground when you launch? :D
  9. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Wow great work!
  10. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
  11. MADNESS Autoworks
    67
    #11 MADNESS Autoworks, Feb 24, 2016
    We did this for a variety of reasons:
    1. The space on the right side is much more limited.
    2. They are very easy to see regardless of where they are located due to the small overall size of the dash and the panel.
    3. We wanted to keep a bit of the classic feel to the dash and after doing a variety of different layouts this layout looked and functioned the best in our opinion.
    Yes, the suspension has been reworked a bit since some of these pics were taken. The car turns and drives fine. We will continue to work on the suspension over time along with all other portions of the car and continue to make it better and better.
    The car has a pretty even weight distribution and has been pretty balanced on launch. Honestly, we have not pushed it as hard is we plan to yet, but will do that soon. Between all the other (paid) projects we have had in the shop and the daily bolt on mods that we are doing our own cars take a backseat at times. We are doing a new clutch for it now along with some additional mods to the backend and plan to get it fired up again very soon. This time we will also do some footage and share.
    Thank you!
    Glad you do! As do we. :)
  12. yellowbritishrocket
    May 16, 2009
    618
    277
    did you leave the donuts up front? why not convert it to coil over...
  13. Firebro17
    I was expecting you to say the gauges are mounted that way as a tribute to the Innocenti Minis... Oh well, nice job.
  14. MADNESS Autoworks
    67
    Here's some footage of it in action!
    [ame="http://www.youtube.com/watch?v=yqWJAZGR5C4"]Mini Mayhem Pt. 2 - YouTube[/ame]
