Engine Drivetrain 2nd Gen S Mahle or CPS forged pistons?
Discussion in 'Tuning and Performance' started by genik, Jan 19, 2014.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    Im thinking of making an upgrade to my R56S wngine with forged pistons. Seems that the piston rings are in bad shape (consuming too much oil) so i probably have to open the engine and replace them, but once i do so why not put forged pistons in there. Friends have advised me for those two brands, Mahle and CPS but i have no idea which of the two is best! Any help on this and where from can i get them as cheap as possible?
  2. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    The Mahle are the better of the two!! When you figure that most endure racing/ GT track/ ect in the Eu are running the Mahle Piston... go with them.
    Just me.................................
    Thumper
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    Why are the Mahle better? Can you please be more specific on the reasons why i should prefer Mahle than CPS?
    I don't think you can wrong with either choice. Personally, I went with pistons sourced from Revolution MINI Works on my rebuild.
  5. Dave.0
    You need to figure out the reason the rings / pistons failed before buying a new set.
    The bore may not be in spec anymore. Don't buy parts until you know why they failed and what the true measurement is.
  6. Firebro17
    Mahle is the choice of many a successful racing venture...
  7. jiminni
    jiminni Well-Known Member
    262
    Ca.
    What brand are they, JE?
