1st Gen R53 Cooper S Making the Xenon headlights brighter
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by nobbyclark, Nov 30, 2015.
  1. nobbyclark
    nobbyclark New Member
    Sep 25, 2015
    13
    Perth, Scotland
    I have an 02 MCS with Xenon headlights. Last week a Gen 3 Mini passed me and it had amazingly bright headlights. Is this just a bulb thing or are the Gen 3 headlight units that much brighter? And what can be done to improve the brightness of my existing headlights?
  2. BlimeyCabrio
    The early first gen xenons were not projector headlights. Not much you can do with them other than replace. The later first gen xenons are true projectors for the low beams, still halogen high beams, but are pretty effective. I believe you can retrofit them, but it's not cheap.
  3. DneprDave
    Moar voltage! :D
    They won't last as long though.
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    From the research I've done, I don't think even retrofitting is possible. You'll run into complications with the self washing and self leveling. Maybe get the best possible bulbs you can get. Throw in some super bright fogs and be happy with the result.
  5. Minidave
    4,591
    #5 Minidave, Nov 30, 2015
    Buy a newer car? Don't drive at night? :biggrin5:
    Please, please please, do not buy a "super bright set of fogs" and run them all the time.
    There's no difference between doing that and driving with your brights on all the time. Either way is annoying as hell to other drivers and makes you look like a dork who's too stupid to figure out how to turn his fogs off.
    If you car truly has Zenons, they should look pale blue when you start the car, and they should "jump" one time immediately after you start the engine as the self leveling cycles, if they don't you don't have Zenons, you have halogens. Replacing the bulbs with new ones will help your halogens, but getting actual Zenons is what you'll need to do to get the lights you're after.
    Converting means getting an aftermarket kit which will not have the self leveling feature - which means you have to be very accurate about your aiming or you'll be blinding oncoming drivers constantly - or buying a newer car with actual Zenons.
    I noticed a difference in the color of the Zenons between my 2003 Cooper S and my 2009 Clubman S, the newer ones are warmer, less blue...and actually give a better light pattern. But pretty much any factory Zenon is way better than any halogen.
    The Gen 3 car you saw may have been running LED lights, the next step above Zenons.....I expect LED conversion kits will be out soon, but they will be spendy. Zenons were a $500 upgrade on my 2009 Clubby, LED's on a new F56 are $1000!
  6. Red Bull
    Red Bull Active Member
    Aug 9, 2014
    525
    208
    I think those are only problems if you don't already have xenons. Going to face lift projector xenons from old xenons is supposed to be plug and play.
  7. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    The first thing to do is properly aim your headlights. The adjustment screws on the MINI are VERY sensitive. 1/4 to 1/3 turn is a huge change. My 2005 MINI had the lights aimed too low when I bought it. I took it out on a dark country road and aimed them properly and about doubled their effectiveness. My buddy had a 2003 with Xenons and his were aimed too low as well. Once I aimed his lights, they were equally effective compared to the 2005-6 lights. (I know the Xenon headlights are self leveling, but there is a static aim adjustment just like old cars.)
    A quick question...
    Are you comparing the Gen 3 MINI to the Gen 1 by the view from the driver's seat, or by the glare you see from oncoming headlights? Those don't necessarily correlate.
  8. BlimeyCabrio
    ^Truth
    Mine were aimed too low on my 2006, also. Fixing that made a huge difference.
    Same thing on my 2011 328i.
  9. mrntd
    If you don't have xenons then I would look to replace the bulbs with this HID kit.
    DDM-HID-Kit-Slim-Ballast-35W-or-55W
    I have them on the wife's car and they work great. She doesn't get people flashing at her and they are aligned right.
  10. Metalman
    Impossible to work correctly.... "IT'S SCIENCE"
    Halogen optics aren't designed to work with a HID bulbs... They aren't interchangeable.... Yes, light will still come out when it's converted.... BUT....
    Daniel Stern Lighting Consultancy and Supply
  11. BlimeyCabrio
    I love Daniel Stern's site. Bought my 65w halogen bulbs from him years ago. Served me well in Locutus Mk1. Which reminds me... I have one of those bulbs in Locutus Mk2, and one normal 55w bulb...
  12. mrntd
    That article has some valid points.
    The difference is the light down the road. When compared to the stock halogen lights on the same stretch of road there is more light, for a farther distance, and a better quality of light.
    Funny how "science" keeps getting corrected. It's only right until it's not.
  13. Minidave
    4,591
    I'm seeing LEDs for sale now.....
    [ame=http://www.ebay.com/itm/2015-New-Ultra-Bright-6000K-White-H4-9003-HB2-ETI-40W-6000LM-LED-Headlight-Kit-/252041238440?hash=item3aaed417a8%3Ag%3AspcAAOSwMmBVuQEB&vxp=mtr]2015 New Ultra Bright 6000K White H4 9003 HB2 ETI 40W 6000LM LED Headlight Kit | eBay[/ame]
  14. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
  15. Metalman
    Are we sure those aren't MINI flux capacitors?
    They sure look like flux capacitors....
  16. BruceK
    Feb 24, 2015
    Texas
    #16 BruceK, Dec 2, 2015
    I've got the same problem with my '02 MINI with xenons. Frankly, even when adjusted correctly, they were never that good. As technology has moved on, they appear worse in retrospect to more modern xexon-equipped cars.
    So, to recap, if you have a earlier Gen 1 MINI and you are fed up with these xenons...
    ...the best (but not necessarily the cheapest) solution, is to replace them with these later Gen 1 xenon headlights. Sure, you'll have to put with the art deco Buck Rogers ray-gun styling :wink: , but they work better at lighting the road because they are projector beams.
    From what I understand, these later headlights are plug and play for earlier cars, right? By that I mean a factory-equipped xexon car to start with, so it would have the headlight washer system and the headlight self-leveling features already.
  17. mrntd
    That is the best solution. Just not the cheapest.
    Sometimes the reflector design is so bad no bulb can fix it.
  18. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    or just buy a used Mini for your son that has the better lights, and then one night, the lights magically swap cars and voila, my 05 has the HIDs I always wanted.
