R56 Mass Airflow Sensor
Discussion in 'Tuning and Performance' started by Homazur, Oct 6, 2020.
  1. Homazur
    Homazur Well-Known Member
    Sep 25, 2020
    234
    279
    So I stalled at a light because engine idling was up & down put it in neutral and started back up then drove to work ~ lunchtime it threw a code mass airflow sensor so I did some research and maybe it’s time for solenoid / actuator? Or Throttle body or all 3
    I have all new plugs and coil packs already any recommendations? It seems like it wants to cut out when come to a light and then it wants to go go go ?
    How many miles has it been sense you had the intake walnut blasted? That is also a sign of carbon build up. It may also be the MAS.
  3. Homazur
    Sep 25, 2020
    234
    279
    Update so sensor changed rock auto $67 and changed and seems so far so good and code clear and no erratic idling and take offs are Thunderbirds Go!
  4. Homazur
    Sep 25, 2020
    234
    279
    Tuesday next week I’m doing the two VVT solenoids because I threw another code again and everything else is good and I’m thinking that 119k it’s time to pull them out and look too see if gunked up? She’s running super but idle is up and down sometimes not all the time~~
  5. MCS02
    What year is your Mini? If it is a gen2 S they need the intake walnut blasted about every 40k. If the valves are getting build up it will start by having idle issues once it gets bad enough it will have a valve stick then it’s bad news
    • Informative Informative x 1
  6. MCS02
    I should say if it’s N14 motor
    • Like Like x 1
    • Bad Spelling Bad Spelling x 1
  7. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #7 cristo, Oct 21, 2020
    I’m having a recurring 2B5C (P115C) code.
    Trying to sort out between MAF sensor,
    throttle body, vacuum leak, or carbon on
    valves (44 K miles) at the moment.
    No other codes. Only threw a CEL
    (P115C) once, but the pending 2B5C
    comes up more and more often when
    I scan for pending codes.
    Runs great, steady idle, and better than
    usual mpg, (although there may be other
    reasons for that last item).
  8. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #8 cristo, Oct 21, 2020
    Will first try a new MAF sensor, then a new
    TB, then pull the intake manifold off and
    get the borescope out to look at the intake
    valves**, then maybe get an inexpensive smoke
    machine to see if there’s an occult leak or crack
    that has escaped my notice so far*.
    Hopefully it will get sorted out well before
    I get very far down that list.
    Other suggestions are welcome.
    *have already replaced the cracked plastic hose
    from the filter box to the turbo intake as well
    as the noisemaker delete and the resonator
    delete and BSH pvc hose plug and OCC and
    new oem diverter valve and all those hoses and
    connections are good)
    **has had oil changes every 5K forever and
    seafoam treatment through the vacuum hose to
    the intake manifold before each of the last 3
    oil changes, and OCC last 15K so intake valves
    probably aren’t too bad.
    • Like Like x 1
    • Agree Agree x 1
  9. MCS02
    #9 MCS02, Oct 21, 2020
    If you have been doing the seafoam treatment then your valves may not be too bad. The long hard plastic tube that goes from the intake to the turbo get cracks from age maybe check that also.
  10. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Do you mean from the intercooler
    exit towards the throttle body?
    I already replaced the one from the intake
    filter housing to the turbo inlet.
    Do you take off the lock bridge to
    get to that (big U shaped metal part
    that goes over it in the photo)?
    I thought those tubes got softer with age? ;)
  12. MCS02
    different tube, getting old is not for the faint of hart.:D
  13. MCS02
    I am sorry, yes the one from the intercooler. Yes I did take off the lock bridge.
  14. Homazur
    Sep 25, 2020
    234
    279
    Kewl I’ll definitely look into doing that while I’m updating the solenoids
  15. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Might just run a borescope down that tube
    since it’d be less bother to do.
    Sorry, Homazur, I seem to be hijacking
    this thread.
    Borescope down my tube. Oh Hellz No! :Dead:
  17. Metalman
    By chance, do you have one of those so called "performance" air filters that gets re-oiled after a filter washing?
    Over saturating the air filter with the oil can cause issues with the proper operation of the mass airflow sensor...
    • Like Like x 1
    • Agree Agree x 1
  18. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Nope, stock oem filter.
  19. MCS02
    Chuck at our age you know we ave to get a borescope every now and then:eek::D
  20. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    I’ve had 4 so far (2 screening colonoscopies and 2 cystoscopies related to kidney stones).
