Mini Camden Mission Controls
Discussion in 'Starting Line - New Member Introductions' started by kristimh, Feb 27, 2014.
  1. kristimh
    kristimh New Member
    Feb 27, 2014
    Hi there! I have a Mini Camden 50 with Mission Controls. I was wondering if anyone knew how to reset the radio / system. My Mini today got stuck on the Mission Control section on the the radio section. I can still play cd's and the radio works only on the station it was on before it got stuck. So I can't change stations and Mission Controls have stopped "talking" now. I un-plugged my SD card for it so hoping it'll reset itself while I'm at work. But if not, I think maybe just resetting the system itself maybe what I'll need.
    Thank you! :)
  2. Jason Montague
    :cornut: 1st post welcome to MA. One of our computer types should be along shortly.:Thumbsup:
  3. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
  4. MCS02
    6,328
    Welcome to MA! I'm a R53 guy so I'm not much help, but maybe disconnected the battery for about ten min.
    I know this resets the ECU so maybe it will take care of Mission Control.
    #5 Nathan, Feb 27, 2014
    Help with problems
    Malfunction
    In the event of malfunctions or error messages,
    proceed as follows:
    Operation by means of the iPhone.
    1. Unplug the iPhone or remove it from the
    media snap-in adapter.
    2. Connect the iPhone or dock it into the media
    snap-in adapter.
    3. Restart the MINI Connected app.
    If the problem persists, proceed as follows:
    1. Switch off iPhone.
    2. Switch on iPhone again.
    If the problem still persists, reset the iPhone. To
    do so, simultaneously press and hold the following
    buttons for at least ten seconds:
    > Home
    > Standby
    If the problem still persists, initiate a self-diagnosis.
    Self-diagnosis: carrying out
    The self-diagnosis tests the connection between
    the car and the iPhone.
    2. "MINI Connected"
    3. "Information"
    4. "Check connection"
    5. "Self-diagnosis"
    6. Reconnect the iPhone or dock it into the
    Self-diagnosis: result
    > Successful connection: "Connection OK"
    > No fault present: "OK"
    > Fault present: self-diagnosis aborts.
    Self-diagnosis: fault rectification
    1. Select the i symbol.
    2. Follow the instructions as they appear.
    If the problem persists, visit the MINI Connected
    support site at:
    www.mini.com/connectivity or contact MINI
    Service.
    If the iPhone has been restarted
    Try unplugging and reconnecting the iPhone or
    removing it from and redocking it in the media
    snap-in adapter in order to use the MINI Connected
    app.
    MINI Connected app is closed
    The MINI Connected app is closed in the following
    situations:
    > If an incoming call is received.
    The MINI Connected app is restarted after
    the phone call is finished. There may be
    delays in the process.
    > When making an outgoing call.
    The MINI Connected app must be restarted
    after the phone call is finished.
  6. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    I have a Camden Edition as well and had the same thing happen to me one evening. Couldn't change channels, change volume and the screen was stuck on something, but I don't remember what at the moment. I tried everything I could think of, even turned the car off while I was sitting at a red light, all to no avail. Got home and said screw it for now. When I came out in the morning it was fine and I have never had a problem since. So hopefully your will reset itself like mine did.
  7. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    welcome to m/a
  8. Zapski
    Welcome to M/A! Enjoy the ride!
    Hopefully the info that Nathan posted will be helpful!
