Breaking down 2003 MINI Cooper engine that had a head gasket failure(75000 km). Let me know if you need any parts. [email protected] Connecting rods, rod bolts and wrist pins sold. Jeremy
Here's a few of the bits: MINI Cooper Engine Block and bearing ladder-$250. Throttle body-$75. Fuel Rail and Fuel Injectors-$150. Water Pump-$40. Belt Tensioner-$40. Oil Pan and pick up pipe-$125. Valve cover with gasket and spark plug tube seals-$125. Engine wire harness-$125. Crankshaft-$250. Oil filter housing-$100. Timing Cover with oil pump-$100. Crank sensor, camshaft sensor, map sensors-$35 and up.
