2nd Gen R56 Cooper S Mini Diagnostics
Discussion in '2nd Generation: 2007+ R55 through R61' started by David Mc, Oct 1, 2015.
  1. David Mc
    David Mc New Member
    Apr 19, 2015
    16
    #1 David Mc, Oct 1, 2015
    I have posted a fairly comprehensive user guide on what I consider to be one of the best diagnostic tools for Mini and BMW here https://youtu.be/-KjUiUOTxS8 for anyone who is interested.
    Although I have a lot of software and interfaces for diagnostics with these cars, I find the Carly for BMW app to be reasonably priced (considering its capabilities, portability and convenience).
    I also wanted to show anyone who is reluctant to attempt diagnostics on these cars how easy it is to avoid rampant dealer charges for this service.
  2. Zapski
    I went to go watch it, but got an error.
    Yep, same for me. Think the link is corrupted.
  4. MCS02
    I got the same error
  5. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Me too...but as with all things computer, I thought it was my error.:rolleyes:
  6. David Mc
    David Mc New Member
    Apr 19, 2015
    16
    #6 David Mc, Oct 2, 2015
    Sorry guys, link has been fixed and just to keep it relevant, here is a clip on using Carly for BMW with my R56 Cooper S
    [ame="https://www.youtube.com/watch?v=ex3linV7Gxw"]2011 R56 Mini Cooper S Diagnostic in under 60 seconds with Carly for BMW - YouTube[/ame]
  7. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I just got the OBD II wifi connector from Detroit Tuned. It's not the Carly recommended unit but I'll let you know how it works once it comes in.
    ELM 327 Wi-Fi OBDII
  8. ScottinBend
  9. nkfry
    nkfry New Member
    Roseville, MI
    Thanks for the shout out, don't forget you'll need to download an app from the iTunes store such as Dash Command for the tool to "speak" with your phone. :Thumbsup:
  10. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Shouldn't the Carly app already work with it?
  11. Eric_Link
    Eric_Link New Member
    Sep 28, 2015
    46
    20
    Yeah, Carly worked with my generic blue tooth obdii. It should work.
  12. nkfry
    nkfry New Member
    Roseville, MI
    I am an Android user, so I don't know the full market of OBD apps for Apple users, but Dash Command was the most prominently used app.
  13. Eric_Link
    Sep 28, 2015
    46
    20
    Carly is the only one that reads all the bmw ecus.
  14. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I can't wait for some coding :)
  15. Germarican
    Germarican New Member
    Apr 20, 2010
    10
    Soldier
    Wiesbaden, Germany
    I have a ikkegol wifi adapter. Wonder if it works. Having an f56 means I have time until coding is available.
  16. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Ok, I've got the wifi odbII connector. It works great with the Carly app. I programmed a couple things. I set the car so I can roll the windows down and up with the unlock and lock buttons on the key fob. The Dash Command app doesn't work yet, from the little amount of tinkering I've done. I may have to try and get a refund for that one.
    I also tried setting the car to auto unlock when the engine gets turned off, but that was unsuccessful and I also tried to set a "shift light" notification but that in combination with the auto unlock messed something up, after I set those codes I had a symbol on the little screen on the tach I'm not familiar with and it wiped out the date and time from the system. Thankfully I had an appointment at the dealer the next day and he fixed it right away.
    SO, The 1st ecu I could code was successful(windows up and down via fob). The 2nd(auto unlock/shift indicator)... Not so much.
    I was able to run diagnostics without any issues.
  17. TWISTER
    TWISTER Active Member
    53
    Web Developer/Designer
    Piedmont Triad, NC
    Any more news on this?
  18. AnthonyA
    AnthonyA New Member
    Oct 25, 2016
    Smyrna,Ga.
    I have this. I originally bought it for my BMW and will try to play with it to to see what it can do. One thing that I found playing with my Bimmer is that a generic wifi obd2 adapter will not do all the functions.You will have to get the Carly adapter to open all the functions,such as changing settings. The generic adapter will allow you to see codes and clear them.After that,everything is hit or miss.
  19. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    ^^^^Keep us posted^^^^
  20. David Mc
    David Mc New Member
    Apr 19, 2015
    16
    I would definitely recommend the Carly adapters with the Carly app, I have an old generic ELM v1.5 Wifi, plus one of the original BMWhat adapters, which both have some functionality with Carly, but their Gen 2 adapters are definitely the go. As far as Dash Command and many of the other generic apps go, they are not BMW/Mini specific, whereas Carly definitely is, so it gives genuine BMW fault codes and has some nice additional features like a "used car check". The used car check can verify the VIN, mileage and even identify if there are any issues with replacement modules in the car (such as non-matching VIN). It also allows you to see the average speed at which the car has been driven since new - which is handy for predicting future issues like DPF problems on a low average speed diesel car, indicating possible excess city usage.
