2nd Gen R56 Cooper S MINI Error Codes
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Jul 27, 2013.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    Where can i find info on that an error code represents? Is there some list of all the possible errors and their eplanation?
  2. Metalman
    All you need to do it click the "Library" button at the top of the page on the banner and follow the clicks...
    As far as a detailed explanation.... well.... Not so much.... More like cryptic hints...
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    i entered library but i dont see what to click on next :confused5:
  4. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
  5. Metalman
    Just like a real library.... You need to start checking things out... There isn't a stern librarian that's going the give you "the look" through those little round librarian glasses.... Just jump in there... You can even make a bunch of noise.. Just....... DO IT...
  6. Nathan
  7. Metalman
    Carp...
    I forgot about Nate.... The Librarian....
  8. Dave.0
    What is the code?
    A lot of us have had codes and can help you find the fix or at least point you in the right direction to fixing it yourself.
    Most of the time the direction you need to go is NOT to the Stealership for an overpriced repair bill.
  9. genik
    genik Member
    Feb 20, 2012
    402
    19
    it was in the pending folder P2187
  10. Dave.0
    You could have a loose or cracked hose leading into the crankcase if they are loose or cracked then they are letting air in causing the change in idle.
    If its a pending code it will clear itself if the problem no longer continues. Check all your vacuum lines and make sure all the connections are tight.
    What year car and model? turbo or SC or Justa?
  11. genik
    genik Member
    Feb 20, 2012
    402
    19
  12. Dave.0
    ok good luck. :Thumbsup::popcorn:
  13. genik
    genik Member
    Feb 20, 2012
    402
    19
    what are your thoughts?
  14. Dave.0
    Really good luck, I mean it.
  15. genik
    genik Member
    Feb 20, 2012
    402
    19
    Just before i had a CEL turned on, i had loss of boost over 4000rpm, this issue was as i say, a on and off issue, meaning that one day it was fine the other it wasn't, can this also be a vacuum line bad connection?
  16. Nathan
    Yes, it could be a crack that is not big or a bad connection that is intermittent. Harder to find. I'd think about a smoke test at a shop. That will show any vacuum leaks.
  17. genik
    genik Member
    Feb 20, 2012
    402
    19
    I was just wondering, if its a mechanical issue (loose connections, cracks etc.) then the issue should happen all the time, it shouldn't be on and off, correct?
  18. genik
    genik Member
    Feb 20, 2012
    402
    19
