MINI OEM Bluetooth Unit - $75
Discussion in 'MINI Related Items For Sale' started by Carve906, Feb 23, 2014.
  1. Carve906
    Carve906 Member
    Aug 13, 2009
    109
    9
    #1 Carve906, Feb 23, 2014
    MINI OEM Bluetooth Unit - SOLD
    SOLD SOLD -- I bought this unit from the MINI dealer at Minis on the Dragon last year. It allows you to have handsfree phone conversations in your MINI. Easily clips to the sun visor and syncs with your bluetooth phone (I used it with two separate iPhones). Holds charge for a long time. You can stream bluetooth music thru the unit's speaker (I've used it this way while working in the garage and placing the unit in a coat pocket). This unit has not seen much use and is in near perfect condition. Comes with charging cable. -- SOLD SOLD
  2. MINIFIED
    MINIFIED New Member
    Jul 19, 2009
    For which generation iPhone? Do you have model #?
    Thanks
  3. Carve906
    Carve906 Member
    Aug 13, 2009
    109
    9
    I will look for a model number this evening when I get home. I used for both an iphone 5s and iPhone 4S. Did not try with previous models.
  4. Metalman
    I'ma thinking if the iPhone has blue teeth, then it should connect.... I don't think blue teeth is affected by the generation of iPhone....
  5. Carve906
    Carve906 Member
    Aug 13, 2009
    109
    9
    Sale Pending...
