MINI S
Discussion in 'Starting Line - New Member Introductions' started by trustme1, Apr 2, 2013.
  1. trustme1
    trustme1 New Member
    Apr 2, 2013
    HELLO EVERY ONE I HAVE A2006 MINI S WITH COLD STRT PRABLEM CODES SHOW ALL CYLS MIS FIRE & STALL DON'T WORK TILL IT'S WOREM UP NEED HELP THANKS
  2. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    HELLO! HAVE YOU TRIED NOT HOLLERING AT THE CAR WHEN STARTING?
  3. Metalman
    HEH HEH...:D
  4. boosted_r56
    boosted_r56 New Member
    May 9, 2011
    29
    Obvious troll is obvious.
    Your caps lock is stuck on.
    Welcome to M/A.....
  6. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the award winning coolest MINI forum on the net........:cool:
    Can you us more info please.
    What codes are you getting?
    How many miles?
    What sort of maintenance has been performed recently?
  8. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Friendly? Now we have to be friendly?:incazzato:
    :D
  9. MCS02
    6,278
    #9 MCS02, Apr 3, 2013
    Not all of us have to be friendly. Just enough of us to keep a good reputation.
    You can be MA's 1%er. :biggrin5:
  10. MCS02
    6,278
    Welcome to MA Trustme1. There is a lot of help here and lots of fun.
    What Nathan said more info we'll help.
  11. trustme1
    trustme1 New Member
    Apr 2, 2013
    THANK YOU FOR YUOR REPLY CODS ARE MIS FIRE CYL #1,2,3,4. HAVE 39815 MILS NO IDEA WHAT KIND OF MINT'S HE GOT 1ST TIME CUSTMER
    First off, there is no need to use all caps please.
    We need more info on this car please.
    I'm getting the impression you represent a shop and have a customer with a problematic MINI. It seems ya'll don't normally work on MINIs too.
    Have you done the basics like make sure the plug wires are installed correctly.
    Checked the Coil to make sure the ends are not corroded
    Taken a look at the plugs
    What about a compression and leakdown test.
    We really need more to go on to be able to help.
