2nd Gen R56 Cooper MINI UK Releases ‘JCW Pack’ & Updated Tuning Kit
Discussion in '2nd Generation: 2007+ R55 through R61' started by Nathan, Feb 1, 2011.
    #1 Nathan, Feb 1, 2011
    Much like the M Sport packages from BMW M that’s offered on non M cars, JCW now has a ‘Pack” for non JCW models. The JCW Pack consists of the:
    • JCW aerokit
    • Challenge spoke wheels
    • Dynamic Traction Control (DTC)
    • Electronic Differential Lock Control (EDLC)
    • Entry strips
    • Sport steering wheel with red stitching
    In other JCW news MINI has officially released the update tuning kit for the Cooper S. HP is up to 200 (in UK trim) and torque remains at 199 lb-ft of torque due to the clutch and transmission not being rated for higher numbers. As before the tuning kit comes with an updated intake, exhaust and software.
    Official Release: A John Cooper Works Pack has now been developed for the MINI and MINI Convertible, offering components that give the cars a head-turning sporting allure – both technically and stylistically. The model-specific interior and exterior components optimise the handling of the MINI and ensure it delivers an impressive visual impact. The John Cooper Works Pack is due to be available from the second quarter of 2011 as a factory-fit option.
    Key to giving the cars fitted with the John Cooper Works Pack their imposing appearance is the aerodynamics package, which lends the front, rear and flanks of the MINI and MINI Convertible an undeniably sporting flavour. The black border around the lower part of the body is highlighted particularly clearly at the front and rear by a centrally positioned indentation. The inner section of the surrounds for the positioning lights or foglamps on the outer edges of the front apron feature horizontal slats. Plus, the radiator grille has the same honeycomb structure as the lower air intake. The side skirts continue the dynamic thread, curving inwards with a sweeping flourish and adding a stylised opening at the rear. As part of the aerodynamics package features, the powerfully formed rear apron includes prominent cut-outs at its outer edges which mimic the appearance of the positioning light and foglamp surrounds integrated into the front apron.
    The 17-inch weight-optimised light-alloy wheels in John Cooper Works Cross Spoke CHALLENGE design ensure the best possible contact with the road. Moreover, the John Cooper Works Pack comes with the traction mode DTC (Dynamic Traction Control) added to the standard-fitted stability system DSC (Dynamic Stability Control), as well as EDLC (Electronic Differential Lock Control) – the electronically controlled locking function for the driven axle differential. DTC mode, which is activated at the touch of a button, raises the intervention thresholds of the stability control technology, making it easier to pull away on loose sand or snow with a degree of wheel spin. The system also allows controllable slip through the driven wheels under particularly sporty cornering. The EDLC system assists a sporty driving style when accelerating out of corners and sharp bends. In tight corners it brakes a spinning driven wheel as required to enhance the car’s traction without adversely affecting its self-steering properties. And that allows the driver to feed the car through corners more smoothly, as well as at greater speed.
    The interior components included in the John Cooper Works Pack also play their part in creating a full-blooded driving experience. These include John Cooper Works door entry strips and the John Cooper Works sports leather steering wheel with red contrast stitching. Cars with a manual gearbox are also kitted out with a John Cooper Works gearshift lever with red shift pattern lettering and a leather gaiter with red contrast stitching. Customers specifying a manual gearbox will also find the handbrake gaiter featuring red contrast stitching.
    The John Cooper Works Pack is available for all engine variants of the MINI and MINI Convertible and can be combined with eight body colours. The aerodynamics package included as part of the John Cooper Works Pack can also be ordered on its own for the MINI John Cooper Works and MINI John Cooper Works Convertible.
    Exclusive to the MINI Cooper S: John Cooper Works Tuning Kit.
    The selection of John Cooper Works retrofit options will also welcome some attractive new additions in spring 2011. Customers keen to sample the sporting driving experience in the MINI Cooper S, MINI Cooper S Clubman or MINI Cooper S Convertible in an even more focused form will be able to order their cars with the John Cooper Works Tuning Kit. Performance-optimised engine management and a specifically designed air filter system enable the twin-scroll turbo engine to develop even greater power. Indeed, the maximum output of the four-cylinder unit rises another 12 kW to 147 kW/200 hp at 5,700 rpm. Plus, the driver can call on maximum torque of 250 Nm (184 lb-ft) between 1,250 and 5,000 rpm when some seriously forceful acceleration is required – and this can be raised to as much as 270 Nm (199 lb-ft) between 1,800 and 5,000 rpm courtesy of the Overboost function. All of which means that the MINI Cooper S can sprint from 0 to 100 km/h (62 mph) in just 6.8 seconds and record a top speed of 234 km/h (145 mph).
    The John Cooper Works Tuning Kit includes a model-specific sports silencer with chrome tailpipes, which optimises the exhaust gas discharge and gives the engine sound a particularly sporting note. It is available for retrofitting on all relevant models with manual gearbox produced since March 2010. It meets the MINI brand’s high standards of quality and safety in terms of both design and engineering and is retrofitted, like all John Cooper Works accessories components, by authorised MINI Service Partners. This means that the car’s warranty will remain unaffected.
    Source - MotoringFile
  2. Metalman
    Hey Jim...
    Looks like MINI is sharing a little love for the Cooper.....
    JCW bumper + Justa Hood:Thumbsup:
  3. Metalman
    So I just noticed this.....
    The JCW Aero front bumper has been slightly changed. Looks like there are some subtle horizontal creases that lead into the fog light surrounds. Weird little change to make.....
  4. Justa Jim
    I like it. Now if I could find some
    "Justa JCW" badging for it. :Thumbsup: :lol:
