I am trying to help my shop get some more info on the rear damper installation. Anyone have a diagram/pic of the proper parts and order of them for the rear Koni yellow's? The instructions from Koni suck....and the shop is not sure of the proper sequence of parts. Thanks
Thanks. I actually got a hold of Chad at Detroit Tuned and he got me all fixed up! Thanks Chad......you ROCK! ! !
They are just rear shocks. Have them take one off, pay attention and reverse the order to put the new Konis in. It should not be that hard since the are only held in with 3 bolts. 2 at the top and 1 at the bottom.
The FSD and Yellows don't share any parts. In fact the yellows have a larger diameter shaft and the need to modify the spring perch and strut perch washer to work. They also have a unique spacer that needs to be installed in the proper orientation on the shaft. Wish the included instructions had been any help.....lol
