More upgrades for Boogie
Discussion in 'Classic Mini' started by yellowbritishrocket, Feb 1, 2016.
  1. yellowbritishrocket
    May 16, 2009
    618
    277
    Time for some more custom work on boogie... this time its time to address that old tired rocker switch panel... half of the switches are not even seating anymore and have a hard time actually working... so i decided to do something different...
    the panel is the one on the right...its a printed lime green/carbon fiber weave pattern... what is going in the slots are LED pushbutton switches... this is being done by WiredbyWilson in england
  2. Minidave
    I really like the looks of what they do, those switches are cool - but wow - $250 for a switch panel....whew!
  3. yellowbritishrocket
    May 16, 2009
    618
    277
    if the pushbutton one is a bit expensive they do a toggle version thats less expensive
  4. Minidave
    I didn't see that on their site, I'll have to go look again....but I really like those LED lit switches!
  5. yellowbritishrocket
    May 16, 2009
    618
    277
    if you look at his fb page he has some new stuff
  6. 00Mini
    Went to the website and the LED switch plate is gorgeous !! Didn't see the toggle switch plate but given how nice the LED is I'm sure it's got to be a nice unit also.
  7. yellowbritishrocket
    May 16, 2009
    618
    277
    here is a picture of the toggle panel
  8. Minidave
    Do they offer labels for the toggles? I think I like the push buttons better for looks, but how much cheaper are the toggles?
  9. 00Mini
    The toggles are nice ... and thanks for the picture.
  10. yellowbritishrocket
    May 16, 2009
    618
    277
    yes i saw a pic he posted where they labeled the panel itself
  11. yellowbritishrocket
    May 16, 2009
    618
    277
    here is a pic with the switch panel and toggles labeled
  12. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    I like it!
  13. yellowbritishrocket
    May 16, 2009
    618
    277
    the panel is coming along nicely...i am also getting a blade fuse conversion box and a electric aux fan set up as well
  14. Minidave
    Which button is for the ejector seat? :D
  15. yellowbritishrocket
    May 16, 2009
    618
    277
    looks like i have to replace the CV boots and while im at it im going to replace the pot joint boots...does anyone know of a trick to pop the joint off? or to reboot the shafts without having to pull them apart
  16. Minidave
    I just pop them out with a large prybar.
    I don't know of any way to replace the boots without taking one end off, I usually take the pot joint end off, it's pretty easy, just remove the clip and it slides right off, then you can put both new boots on and pop the joint back on.
    To get the wheel end joint off, hold the shaft vertical and hit the joint downward with a 3 lb hammer, they usually pop right off.
  17. yellowbritishrocket
    May 16, 2009
    618
    277
    im gonna give that a try here soon... today before i got too deep into this tomorrow i went through and ensured i could loosen all the bolts like the ball joint ones
  18. yellowbritishrocket
    May 16, 2009
    618
    277
    it took a bit but i got the driver side done today! the longest part was trying to get the upper and lower ball joints loose...after a deadblow hammer, bolt breaker fluid and even a torch still nothing so i used a tie rod remover to force the bolt out... and boy when the top one popped it scared the hell out of me... i thought i broke something! but once i got the knuckle off i found it easier to to pop the zip tie off the pot joint and pull the axle out that way... gave the joint with a whack with a hammer and off it popped! repacked the grease on both ends and refitted... putting it all back together i put some copper anti seize in the mount holes for the ball joints so i shouldnt have a seizing issue. i will tackle the passenger side in a few days when i get a chance but that tie rod remover was a real time saver!
    on a related note... any tips or tricks for removing the top arm so i can replace the cone?
  19. yellowbritishrocket
    May 16, 2009
    618
    277
    #19 yellowbritishrocket, Mar 6, 2016
    boogi1.jpg boogi2.jpg boogi3.jpg boogi4.jpg So here is a rundown
    I got most of the assembly torn down except i ran into a major issue with stuck/seized upper and lower ball joints and even the track rod was seized... not even a micro torch could unseize it... so i ended up getting a tie rod remover tool that forced the bolt out... scared the hell out of me when it finally released, thought i broke something
    finally got the knuckle out! didnt get pics but i cleaned out the grease from the ball joints and wheel bearings and repacked with Redline CV2.. and repacked the grease in the upper arm and suspension cone cup
    I found it was easier to just to unclip the axle at the pot joint boot and pull it out that way
    got the cv joint and pot joint repacked with grease and rebooted
    and now all back together... with copper grease in the ball joint mounts and tie rod mount
  20. Firebro17
    Welcome to the wonderful world of ball joints Roger!
