Suspension Brakes 1st Gen Moving from fixed to adj camber plates
Discussion in 'Tuning and Performance' started by 00zero, Oct 22, 2010.
  1. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    I installed the Ireland fixed plates and i like them allot but i have about a half degree difference between sides (1.4 vs 1.9).
    i'm sure on my daily driver i will never notice the difference but knowing it is there kinda bugs me. I have been pondering going to vorshlag plates.
    Other than the knowledge that my camber in the front is symmetrical will i notice any other difference in the switch?
    -Jonathan
  2. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    Catawba (near Roanoke), VA
    I just installed vorshlag plates. They are made extremely well but have no rubber bushing so the ride is a little rough and sharp bumps are transmitted as sharp bumps. What you hit is what you feel.
  3. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    Jon,
    All of these decisions depend on just what you are doing with your Mini.
    I would tell you that the camber difference you have is inconsequential unless you are competing with your Mini and are looking for every single 100ths of a sec.
    Like above said, the ride will suffer with vorshlag plates
  4. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Unless you're going to track your car a lot...
    I'd just keep what you've got. Now, if having adjustable plates will get you laid much more often, then you should definantly get them. But without that benefit, the rubber bush in the fixed plates will give you a nicer ride on the street. The assymetry in the camber isn't really much of a deal on the street (like Greg said).
    Matt
  5. Onasled Racing
    Jul 19, 2010
    172
    Anyone have experience with this? Test results? :ihih:
  6. minimark
    Went from the IE fixed plates to the Vorschlag adjustables and have found no discernable difference in the amount of times I'm getting laid..... if anything maybe less because I'm spending more time at the track.....
    Opinion: If your just wanting to be better in the twisties on the street and might do a very occasional track day the IEs are OK.....But if your going to track a good bit, then the adjustables by Vorshlag are the way to go.... Your car will handle better, it will be quicker and more precise in every faze of the corner.
    I've heard umbrella girls dig the adjustable plates.
    My IE plates gave me 1.8 & 1.9. Guess I'm lucky in camber & love. :smilewinkgrin:
  8. beaner
    beaner New Member
    44
    a buddy of mine did a MINIs and girls in mini skirts calendar. when the model came over to my car she said, "i thought these were going to be hot cars." i told my friend, "i thought these were going to be hot models."
  9. minimark
    So next time I'm at the track I should pull over to the umbrella girls, pop it open and ask them if they want to see my Vorschlag?? :)
  10. ScottinBend
    Only if you don't want to go back to that track.........:D
  11. Mr. Jim
    I was considering the IE fixed plates, but I spoke with Way and the only ones he is currently recommending are the V's.
    As far as more sex, I suspect that if the mrs. Finds out the price there will be less!!
  12. BThayer23
    #12 BThayer23, Oct 22, 2010
    Buy me a beer sometime and ask about the two girls from law school. Adjustable camber FTW.
    Adjustable camber plates add a little bit of violence to your street driving, give you that tight cornering, and amplify road bumps and feel. Totally worth it if you can live with it.
  13. ScottinBend
    I have been running the IE adjustable ones with no issues for 4 yrs now.
  14. goaljnky
    3,105
    394
    2 cars. 9 years. 0 issues.
  15. Justa Jim
    Note To Self: Remember to buy Ben a beer at MOTD 9. :Thumbsup:
  16. minimark
    Never had a problem with mine either. Only reason I changed was to try and take the car to the next level on the track....
  17. minimark
    Cut him off if he starts asking legal questions.....LOL
  18. Onasled Racing
    Jul 19, 2010
    172
    Unfortunatly the IE adjustable plates fall apart. Literally, I have jacked up cars with them on for a long while and the strut along with the bushing just falls out of the plate. I like IE and use their race plates on my Mini, so I do hate to see this happening. Have never heard of any bad things about their non-adjustable.
  19. jiminni
    jiminni Well-Known Member
    262
    Ca.
    My coilovers would not work with the Vorshlags, used the Hotchkis instead. I like the way they look under the bonnet compared to the V's :Thumbsup:
  20. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Another thing to look at...
    is if your struts have a long shaft, make sure that there is good clearance for them in the camber plate. I've had to mill both the RDRs and the Hotchkiss so that I could mount up my Ledas. Another fix was to just use some spacers (think washers) between the upper spring perch and the upper bushing/ball-joint. But this lifts the front end...
    Matt
