1st Gen R53 Cooper S Multiple Flexpods?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by nitrogen, Sep 6, 2010.
  1. nitrogen
    nitrogen New Member
    Sep 5, 2010
    I don't think I completely understand Cravenspeed's Flexpod mounting system.
    What I'd like to do is mount a scanguage in an R53 (2005 Cooper S) is this:
    Put a scan guage up at "3 O'Clock" and then a nuvi GPS at "10 O'clock"
    Is this possible?
  2. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
    Almost anything is possible just call Kellen and tell him what you would like to accomplish.
  3. BThayer23
    The R53 flexpod system has two mounting points on either side of the tach, at 3:00 and 9:00. Then you attach arms or gauge pods to the mounting points and position the devices where you see fit. For example, you could mount the scangauge arm on the right side and the GPS arm on the left side, and then rotate each arm to the position you desire, such as 3:00 and 10:00, respectively. It's pretty sweet.
  4. ScottinBend
    This is how I have mine mounted....
  5. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    I would suggest something similar to Scottinbend's setup. He used a Bracket Z. If you had a long arm on the GPS you could run it across the back of the tach to the 10 o'clock spot while leaving the ScanGauge on the included short arm.
