2nd Gen R56 Cooper S Must have tools for our mini's?
Discussion in '2nd Generation: 2007+ R55 through R61' started by haliphics, May 3, 2017.
  1. haliphics
    haliphics New Member
    Dec 30, 2016
    61
    In curious what are some of the most improtant tools to own to maintain and modify our Mini's. Ive never really used ratcheting wrenches or flex head wrenches. Now I find them a god send tool for my 09 JCW. What did you find was a great help on your car?
    Sent from my LG-H830 using Tapatalk
  2. DneprDave
    The most important tools you can own for working on your MINI are: An OBD2 code reader and a Bentley manual.
    As I get older I find I use my credit card more that my tools these days.
    You need a good basic set of metric tools. Make sure the sockets are 3/8 drive & 6 point. You will need a set of metric Torx bits too. Don't forget the metric screwdrivers & hammers. :wink:
    If you can post what job you are contemplating doing it will be easier to tell you what specific widgets you'll need.
    Lots of folks are away at the dragon. More folks will be here to help next week.
    Welcome to M/A.
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #4 Qik, May 3, 2017
  5. Red Bull
    Red Bull Active Member
    Aug 9, 2014
    524
    207
    You forgot a metric crescent wrench :crazy:
    A set of torque wrenches are always good to prevent things like stuck drain plugs, spark plugs shooting out of the head, broken studs on the strut mounts, and other stuff that will make your repair turn into a nightmare.
  6. Minidave
    The spark plug socket needs to be 12 point, not 6.....
    I've found the best way to get the torx screws out of the rotors is to tighten them slightly before you try to loosen them, then they come right out. Be sure to use a bit of anti-seize on them when you put them back in too.....
  7. DneprDave
    I used an air impact wrench to remove the screws from the rotors.
  8. Metalman
    If you get rid of the runflats.... Keep one of these in the boot...
    • Funny Funny x 3
    • Like Like x 1
    Dead blow hammers FTW! :)
  11. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,705
    924
    physician
    York, Pa
    BFH for when the deadblow hammer doesn’t work.
  12. Dave.0
    AAA and any credit card.
    • Funny Funny x 3
    • Like Like x 1
  13. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Couldn't agree more.. so many folks use the "Arm" torque" wrench..
    Also agree with the dead blow hammer.. :D
