My kids are the best......Mityvac......
Discussion in 'MINI' started by moreorless, Jun 22, 2010.
  1. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    For Fathers Day they all chipped in and gave me a Mityvac 7201.
    Any tips on it's use with respect to 1st Gen MCS engines?
    .....Les
  2. lotsie
    stagehand/part time detailer
    Right here
    What is a Mityvac 7201? Some kind of vacuum cleaner:confused5:
    Mark
  3. moreorless
    Aug 17, 2009
    343
    14
    "Provides a clean and simple way to evacuate & dispense fluids. Vacuum pressure extracts transmission fluid, brake fluid, coolant, gear oil and engine oil. Flow (GPM): 2, Tank Size (gal.): 2.32, Suction Hose Length (in.): 5 2 rigid dipstick tubes Automatic flow-control valves prevent overfilling Durable poly construction resists rust and corrosion."
    Features and Benefits:
    * The Fluid Evacuator Plus, a large 8.8 liter (2.3 gallon) capacity bi-functional manual unit, can be used to extract and dispense a wide-range of fluid types including: engine oil from crankcases, brake fluid from master cylinders and most hydraulic brake systems, gear oil from transmission cases, coolant from cooling systems, power steering fluid from pump reservoirs, and so much more.
    * The Fluid Evacuator Plus provides a clean, and simple way to evacuate & dispense fluids.
    * An automatic flow control valve prevents the unit from overfilling during use and automatically shuts off at 8 liters.
    * The reservoir is constructed of durable polyethylene and will not rust or corrode.
    * This kit comes with 5 ft. of flexible hose and two rigid dipstick tubes for engine oil removal.
    * This unit can also be used in conjunction with Mityvac 07205 Fluid Evacuator Brake Bleeding Accessory Kit to bleed hydraulic brake systems.
  4. Metalman
    That's what that crazy NASA girl should have used instead of diapers.:arf:
  5. Jason Montague
    :lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::Thumbsup:
