R56 N12 to N16 engine swap/ oil pump
Discussion in 'Tip's, Tricks and How To Articles' started by sx19842000, Dec 19, 2022.
  1. sx19842000
    sx19842000 New Member
    Sep 2, 2022
    I purchased a used engine for my 2007 Base Cooper.
    However, what I received instead of the N12 engine. Was a later gen N16, that has the electric oil pump instead of mechanical pump.
    Question would be. Is there away to incorporate using the electric pump in 2007 N-12 car? Or do I have to change out oil pump to mechanical pump, that is used on the 07 models?
    Thanks,
    sx19842000
    6,317
    I am not sure. It would depend on what activates the pump. I will have to research that one.
  3. 00Mini
    2,263
    While we wait for the wise and all powerful MCSO2 to come up with the answer let me welcome you Motoring Alliance.
  4. MCS02
    6,317
    A very short search looks like the pump is controlled by the ECU. If your N12 is not, I would think it would be a very big headache to do it. I am not sure if you can pin it into the ECU or not, even then It would take programing the ECU.
    you could give https://www.allmagautoparts.com/ or https://www.detroittuned.com/ a call they would know the answer.
  5. 00Mini
    2,263
    Very informative and because of answers like this one you are paid the big bucks. :D
  6. sx19842000
    Sep 2, 2022
    I appreciate your reply. I kind of figured the oil pump would have to be tied into the ECU somehow. But the particular's are beyond my knowledge.
    I will try your tips and see what they recommend.
    Otherwise my thought would be to just change out the oil pump from the damaged base engine I have.
    Only thing about doing that would be the question?
    Is the drive for the oil pump the same on the N-16 engine as the N-12?
    IF SO, THEN TO CHANGE THEM OUT SHOULDN'T BE A BIG DEAL. MAYBE ANOTHER QUESTION FOR WHOM YOUV'E RECOMENDED.
    Sorry for the Caps! Lock on!
    Thanks,
    sx19842000
