NASA & BMW GTS2 race car :: 2003 MINI Cooper S
Discussion in 'Member Garages' started by Alan, Oct 11, 2011.
  1. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    2003 MINI Cooper S (2011-10-11 12:32:10)
    Nice....Because RACECAR! :Thumbsup:
  3. 00Mini
    2,227
    Nice R53 race car in the bestest year and color !!
  4. MCS02
  5. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    I would have to agree! :Thumbsup:
  6. Nathan
    Garage of the Day 11/6/14
  7. Dave.0
    RACE CAR. :cornut:
  8. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    Awesome car dude!
    What wheels/tires do you run?
  9. Nathan
    Popped up in my Random Garage feed. Always did like this car.
  10. Alan
    Alan Active Member
    98
    It's being fitted with 15x9s now so I can run 225/45/15 R7s. It's gonna require body cutting and bending and flares because of the ride height its run at.
  11. UKCoopeR
    May 21, 2009
    293
    109
    VA,USA and UK
    I spy a fun looking rule change for FWD cars in GTS :D
  12. Alan
    Alan Active Member
    98
    Yes, it took me two tries to get that passed.
  13. Alan
    Alan Active Member
    98
    Now with 15x9 wheels, 225/45 R7s, and eyes. :ihih:
  14. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    any setup tips? I'm going HPDE's first then going to GTS with my 2005 R53
    current setup
    KW v3 coilovers
    eibach camber plates, 0 toe both ends, -2.5 in front rear is whatever it managed to get, I think 1.5 in rear
    JCW front calipers
    15x8 wheels with 205 re51 tires
    bone stock engine with a cone filter, was also going to run autocross in STX class
    Next up will be rear sway, and then bracing and a cage in a year or two, who build your cage?
  15. UKCoopeR
    May 21, 2009
    293
    109
    VA,USA and UK
    I would suggest 225 over 205. I had trouble keeping 205s cool enough and I just do TT with the mini so it is shorter stints that a full race. 205 will be fine to start on, just like jcw brakes but once I got fast enough to be at the pointy end of the timesheet they couldn't last.
  16. Alan
    Alan Active Member
    98
    I run toe-out front & rear.
    If you can fit wider tires, do it. It was a huge improvement going from 205 tires on 7 inch wide rims to 225 tires on 9 inch wide rims. And 225 R7s are wide - same as 235/245 tires of other brands.
    Illicit Motorsports built the cage. Tell Jason I sent you.
    https://m.facebook.com/illicit-Motorsports-110220339075198/
  17. UKCoopeR
    May 21, 2009
    293
    109
    VA,USA and UK
    I also run toe out, missed that. I did start with zero toe but pushed it more and more out as I got comfortable with the car and it does magic to the speed of turn in.
