2nd Gen R56 Cooper S Need 6 speed transmission
Discussion in '2nd Generation: 2007+ R55 through R61' started by Eric_Link, Dec 15, 2015.
  1. Eric_Link
    Eric_Link New Member
    Sep 28, 2015
    46
    20
    My housing is cracked. What is the best source for used or rebuilt mini transmissions? Anyone have a good one?
  2. Metalman
    Pull it...
    Take it to a shop that is capable of welding aluminum... (Don't even think of using JB-Weld)... Cleanliness is next to godliness when it comes to welding aluminum... So if the crack is in the case that holds the fluid, be prepared to drain it. They will need to "V" notch the crack and they will be able to do the repair from the outside of the case...
    While it's out consider OS Giken clutch and a mechanical limited slip... You can justify this because you didn't need to buy a replacement transmission...
    OR....
    Buy a replacement / rebuilt unit, and think about what you could have done...:D
  3. BlimeyCabrio
    Yep, If it's just a case crack, I'd have it welded also.
  4. Eric_Link
    Sep 28, 2015
    46
    20
    Thanks guys, I should know more details later today. That's very helpful.
  5. Eric_Link
    Sep 28, 2015
    46
    20
    Update: found a low mileage transmission with LSD... On the way. Already did the clutch this year. New brakes and sway bar also. Should be good!
