1st Gen R53 Cooper S NEED HELP figuring out low vacuum issue! Feel like I've tried everything....
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by silence238554, Dec 6, 2015.
  1. silence238554
    silence238554 New Member
    Dec 6, 2015
    11
    Broadcast Technician
    Oakland, CA
    Hey everyone, first post here on MA, sorry its a long one but I need all the help I can get on this. It all started when I had to do a head gasket job on my car. The head had warped around Cylinder #2, allowing coolant into the combustion chamber & vice-versa. So, I pulled the head, took it to a machine shop, had it leveled (was slightly warped around cyl. 2). They also replaced my exhaust valve guides and all valve seals. Re-installed w/ OEM Head gasket, IM & EM gaskets.
    Firing it up, the car was very hesitant to start, but would eventually stumble to life after cranking for a while. The first thing I noticed was if the throttle was blipped up to 2-3k & let drop, it will either fall to 5-600 RPM, catch itself, then settle at a normal idle of 800, or just fall to 0 RPM & die. Also, my boost gauge is only showing 10 in HG at idle. I believe this should be closer to 15. The idle is also rougher than normal & loud - causes whole cabin to drone. First test drive, it threw a P1498 - unmetered air after compressor. Okay, a vacuum leak!
    Listening around my engine bay with a length of hose up to my ear, I stuck it down behind the radiator & could hear the green gasket leaking. I ordered a new gasket, replaced it, still leaking. Okay, well, It's possibly time to replace the plastic inlet pipe. So, I order up one of those along with a new OEM green jam gasket. I put it all back together & it's running a little better, as in, it's not dying anymore, but it is still bogging & not reading sufficient vacuum.
    I took it to a dealership & they ran a smoke test, found nothing. They reset adaptations & suggested driving it for a while. On my way home, I threw a P0303, Cyl #3 misfire. Cleared it & it hasn't come back.
    I went to Home Depot, bought an air compressor & PVC cap to rig up my own pressure tester. Pressurized the system & right away the damn green gasket is leaking, not even holding 1 PSI. Also, I found that the BPV housing was leaking like crazy. So, I order a new Detroit Tuned BPV
    Today, I installed the DT BPV as well as re-aligned the SC inlet pipe to hold as much pressure as possible. I was able to get it to hold about 5 PSI before leaking any air, which might be a record considering how terrible that gasket design is. I actually had to put 1/4" nylon spacers in between the TB & TB support bracket along with longer bolts in order to get the mouth at the bottom to align properly.
    So then, I'm excited. I finally got the whole system to hold pressure & along with the new BPV, I should be off & running! FALSE! If anything I'm back to square one! Significant bogging when I let the RPM fall & pulling into my driveway from the test drive around the block, the engine didn't catch itself & just died. Still only pulling 10 in HG.
    In addition to all this, we actually have another R53 & I have tried swapping coil packs & MAP/TMAP sensors between the cars. No change whatsoever. Also, i'm not sure if this is just a part of the
    None of these symptoms were present before the HG repair. I apologize for the marathon post but i'm completely out of ideas. I feel like I've tried absolutely everything..... open to any ideas at all, this project started over 2 months ago & has taken up every weekend since :(
  2. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    are you putting the green gasket on the SC inlet first then the inlet tube jammed onto the green gasket? I'm sure you are but want to confirm.
  3. Canusrufis
    208
    103
    Winston Salem NC
    and boost gauge is in "vacuum" at idle right?
  4. minimark
    Smoke test it.
  5. silence238554
    Dec 6, 2015
    11
    Oakland, CA
    Correct, on the SC first, seated completely.
    Yup, boost gauge is in Vacuum, but not enough vacuum. Should read at 15 in HG, mine hovers around 10, fluctuating back & forth depending on how warm the engine is (suspect wherever the leak is is contracting / expanding).
    Did this, they didn't find anything. After realizing that smoke machines only pressurize to about 1 psi, that's when I bought an air compressor & rigged up my own pressure tester.
  6. ScottinBend
    MAP sensors?
  7. silence238554
    Dec 6, 2015
    11
    Oakland, CA
    I think you may have just nailed it-
    I just back probed my MAP & TMAP sensors. What I'm mainly wondering is - What is considered "out of spec"? How off from the OEM spec should a sensor read before replacing? These are the measurements I took vs. Bentley spec.
    I have hi lighted the values from my sensors that I feel may be problematic-
    Pin1/Pin2/Pin3/Pin4
    MAP (Key On, Engine Off)
    0.0/NA/4.99/4.06
    (Idle)
    0.0/NA/5/2.4
    TMAP (KOEO)
    0.0/1.31/5/1.95
    (Idle)
    0.0/1.3/5/1.12
    Bentley-
    MAP (KOEO)
    0.0/NA/5/4
    (Idle)
    0.0/NA/5/1.8
    TMAP (KOEO)
    0.0/3.9/5/1.90
    (Idle)
    0.0/1.25/5/0.9
  8. silence238554
    Dec 6, 2015
    11
    Oakland, CA
    Hmm.... well, just swapped in a set of known good sensors & the car runs exactly the same.... So..... any other thoughts?
  9. nkfry
    nkfry New Member
    Roseville, MI
    Are your intercooler boots seated properly and not tucked under the clamps?
    Is the engine in time?
    Check the MAP sensor source from the black tube, as some people have broken the gray line that goes to the MAP sensor and have similar issues.
  10. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I had a problem with the gray line not sealing properly at the end. The line was not cracked or broken but must have leaked slightly depending on the engine movement. Smoke test could not find leak. I replaced Ox and MAP sensors but still infrequent error code. I finally replaced the line and all is well. I suspect when I replaced the line it sealed better at one of the ends, I think at the Supercharger end.
  11. silence238554
    Dec 6, 2015
    11
    Oakland, CA
    Yup, intercooler boots are seated properly. when pressurizing the intake system I made sure to soak them with soapy water to look for bubbles & they didn't show anything.
    The engine is for sure in time. When I did the head gasket, I second guessed myself on the position of the timing marks so I pulled the timing cover & lined up the links & everything.
    I sprayed that MAP sensor line with soapy water as much as I could but it's pretty difficult to see where it seats down into the black intake pipe.
    Interestingly, the car has started running perfectly on occasion once it's had time to warm up. It doesn't always do this, but it seems possible that if there is a leak, once it's warmed up the material expands, seals itself and allows the car to pull proper vacuum. Reads at 15 in Hg, idle falls to a solid 800 RPM, everything. Unfortunately, it doesn't last very long. I'll go out to drive it the next day & it starts / idles like crap again.:mad2:
  12. nkfry
    nkfry New Member
    Roseville, MI
    The MAP sensor and brake booster line aren't under boost, they are under vacuum (as is the rest of the system until you accelerate and create boost instead of vacuum), so the soapy water solution isn't going to show any leaks. You will need to either pull the intake tract apart again and inspect everything or find a shop that is proficient in finding such pesky leaks.
  13. Dave.0
    Hoping you are not using something like Alta silicone intercooler boots. OEM rubber boots seal best.
    Also, take off your intercooler, seal off one end and fill it with water. If it leaks you have found your issue. I had a corner rub and tiny hole developed over time. I cleaned the I/C with degreaser and JB welded the hole to seal it.
    Later I picked up a GP I/C just because.
