ok my baby 2003 mini s is running like a old hag lately... on the obd2 read it shoee p0302...cyclinder 2 misfire....when i went to replace the spark plugs...all the other cyclinders are goood but number 2 is oily....as of late im awaitng my valve gasket and ingintion coil to come in..ill post a update as soon as i get it and replace it...:cryin:
Neither coil nor valve cover gasket will correct oil on the spark plug. It is very low probability a new coil will make your car feel young again; new spark plugs, wires, and a clean air filter perhaps, for a while. Tell us where the oil is on the spark plug? If it is on the lower threads and the plug shows signs of fouling, then look to worn valve guide or piston rings.
