Entertainment Electronics 1st Gen Need recommendations...
Discussion in 'Tuning and Performance' started by MC40, Nov 28, 2009.
  1. MC40
    MC40 New Member
    Tyler, Texas
    ...for the best way to wire up my i-phone 3G to my '04/S audio system? We would like to play our i-tunes thru the car's audio. The audio system now in the car is the standard factory CD/radio system for that year. It is not the H/K system nor do we have the multiple CD changer or satellite radio.
  2. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    We use the DICE units for this. It will play through the stereo and you can use the Ipod or steering wheel controls to go through songs.
  3. BThayer23
    I had my dealer install an aux input jack on the access panel below the toggle switches, and I use the Kensington LiquidAUX (LiquidAUX™ for iPhone and iPod - K33429US - Kensington) to listen to music. The cable works with both my iPod video and iPhone 3G, and the power unit incorporates a ground loop isolator to reduce hiss and static. You can't use the steering wheel controls to browse for songs, but I usually use shuffle so that doesn't bother me. I'd also recommend the Craven Speed iPod Cradle (Holder for iPhone, Ipod and BlackBerry devices.) to keep the display up where you can see it.
  4. MC40
    MC40 New Member
    Tyler, Texas
    Thanks, I forgot to mention that we don't have steering wheel controlls for our audio system. I've seen the DICE harness on-line but not the Kensington. I will be sure to check that one out as well.
  5. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    I just use the Aux input...
    but I also have Nav and installed a video switch so I can put vids on the nav screen. When my oldest was younger, she liked to watch slideshows of her favorite subject: herself!
    Matt
  6. BThayer23
    More notes about the Kensington setup: it uses line out for audio, not the headphone jack, so the sound quality is better. Also, don't leave it plugged in overnight. The circuit in the cigarette lighter adapter will drain the battery on your device.
    I'm sure other brands exist, but I haven't researched them since Jan 09; Kensington was the first to offer a line out connection incorporated with a cigarette lighter adapter that worked with the iPhone 3G. I used a Monster Cable unit with similar results before I got the iPhone 3G, and Belkin always puts out a bunch of these things.
  7. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  8. Gutterman
    Gutterman Member
    Apr 24, 2011
    So looking to upgrade my audio would like to add iPod , has anyone looked new units that have USB on the front & back for cable output , if so are they plug & play they say they will fit , ( 07 mini cooper S convertible) . Will I lose my steering wheel controls , JVC has 3 models starting at less 100.00 on Amazon.
  9. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    I am using the aux cable plugged into the back of the head unit and then my headphone jack on my iphone 4. (2005 R50). It is not top notch fidelity but neither is over the air radio either in my opinion.
    There is also a small adapter unit that plugs into the bottom of the iphone that accepts both a charger cable and adds lineout. I dont know what quality this provides.
    Since you font have steering controls, (mfsw), you can also look at Parrot Bluetooth modules. I don't recall the model numbers but I think if you look at the 9000+ series you will see that they include bluetooth sound streaming and also a small control module/callerID that you can locate on dash etc.
    With this you get to use Iphone voice commands for dialing or itunes playing.
    Good luck.
