New 4 point belts for MINI?
Discussion in 'General Chat' started by ScottinBend, Sep 28, 2009.
  1. ScottinBend
    Anyone interested in a new belt system?
    :devil:
  2. cct1
    #2 cct1, Sep 28, 2009
    Well, you have a "post" picture, fully latched up, but how about a pre-latched picture (with the driver in place, for reference), I really need to see how this looks unlatched, i.e. how far will those upper restraints go to the side?
    Failing that, do they make one with, say, 1/4 inch upper harness belts? Those look like 4 inchers, those are just way too wide....
    And are you absolutely sure this is a 4 point harness? Maybe a close-up of where the fifth belt should be, to confirm one way or another (Here's to hoping it's only a 4 pointer...).
    Not sure how appropriate that belt setup would be at say Goaljnky's workplace though....
  3. old81
    1,542
    It has a certain allure, I like green. :arf:
    Thats very unsafe for track use. The belts do not have a guide to keep them in place at the top of the seat. During an incident they may slip off the seat and allow the torso flail about. Also since it only a 4pt system in the event of a head on incident there is nothing to prevent submarining.
    BTW cct1, those are 3" belts.
  5. goaljnky
    3,105
    394
    so the first 4 point seat belt hookup with built in airbags?
  6. cct1
    #6 cct1, Sep 28, 2009
    Doesn't matter, they're still too big.
  7. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    I think they just sort of draped those over her for the photo, they probably aren't mounted in the car.
  8. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    Where's the pic of the belts? I don't see any stinkin' belts....
    Mark
  9. ScottinBend
    Same problem I had when I first looked. The wife had to point them out to me.
  10. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    I have 3" Sparco harnesses and I love the width. I couldn't go skinnier. How much do you want for your harnesses and do you have pads?
  11. Doggybags
    Doggybags New Member
    You know, if you look really, really, really, really hard, you can tell that's not a MINI.
    I figured it out after a looooooong time :aureola:
    Nothing MINI about those belts, or airbags....
