Way Motor Works has been working along time and we finally have it. The R60 MINI Countryman 22mm Rear Sway bar. After several test fits and trial of different sizes and positions we have finally have our WMW bar available. We tried 19mm bars but it just wasn't enough to be worth installing. So after trial and error the good old 22mm bar won out as being the best for reduced body roll and neutral handling without too much oversteer. We also powdercoated it in black to make the bar stealth as most R60's are still under warranty and we don't want the dealer to give you a hard time. The WMW bar is a 2 adjustment bar as 3 was not necessary or even fit. Then the sway bar bushings are poly with a grease channel to hold the grease in, but if you need to regrease the bar the sway bar bushing brackets have zerk fittings to make it a snap.
