Suspension Brakes New GP control arms
Discussion in 'Tuning and Performance' started by fngolfer, Aug 12, 2013.
  1. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    Anyone know if the rear lower control arms on the new GP are shorter than your average R56? I would think so since it is sits lower from the factory and I don't see much camber on them. May be interested in buying them instead of adjustable ones. Hmmmm.
  2. Metalman
    Real OEM lists the same part numbers for the GP control arm, so they would be the same with no difference....
    However the GP Trailing Arms show a different part number, but that is probably due to the fact that the GP has a different wheel hub that doesn't fit on the non-GP.... There could be other differences as well...
  3. fngolfer
    Apr 1, 2012
    100
    46
    Los Angeles
    So it probably won't bolt on to an R56.
  4. Agbullet25
    Agbullet25 Member
    Apr 2, 2013
    40
    23
    Central Texas
    If the hub is different I'm inclined to say no it won't bolt onto a normal R56.
  5. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    They are the same control arms as the stock R56.
    I put a set of Hsport Rear Camber links on to take some of the neg camber out and get the alignment dead on.
