1. Bartman
    Bartman New Member
    Jan 1, 2019
    #1 Bartman, Jan 1, 2019
    Hi everyone. I'm a nearly new Mini owner of a yellow 2004 Cooper. I'm handy with wrenches and also own a Miata. My question is that the 04 has about 130k on it and I see some pics leak which I suspect is from the crank angle sensor. Also, in the pic attached is there a missing engine cover as the 20181229_131721.jpg bolts are not attached to anything. Overall is there anything I should be aware of?
  2. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I'm not a mechanic...don't even play one on the internet.:) But I am here to say WELCOME to a great site with greater people. I am sure some of the gurus will be along to answer your questions.
  3. wmwny
    4,048
    2,246
    Welcome to M/A!
    I'm not into Miatas, but a friend here in M/A is, and you should contact him, IMHO. He goes by the nickname of "Crashton" and should put you back on the correct Miata path in a jiffy.
  4. Bartman
    Bartman New Member
    Jan 1, 2019
    Thanks - the Miata is fine and I am already a Miata forum member. This post is on the Mini and wanted you experts to chime in on the oil leak and the odd bolts I see. Sorry if this is in the wrong section as I posted from my phone.
    Welcome to M/A. I'm the guy who gave you the link on Miata.net that brought you here.
    That missing undercover isn't a big deal it only covers the the very front behind the bumper. That bolt picture you posted is more worrying. It's been over 3 years since I've been under an R53 so I don't remember what those are for. I'm sure someone will chime in here soon with an answer.
    You probably should buy a Bentley manual for your car. It sure will come in handy.
  6. Bartman
    Bartman New Member
    Jan 1, 2019
    Cool thanks.
    That bolt is the same on both sides. Here is the photo.
  7. MCS02
    Those bolts hold the arm that goes from your sub fram to your bumper. There should be two bolts in them and they need to be tight. When it’s all tight it gives the front integrity in an accident and stiffens the sub fram. The bumper completes the box. This needs to be take care of. I don’t think you will find the bolts anywhere. If I remember correctly they are self centering. Try Allmag, great guy and a sponsor.
    https://www.allmagautoparts.com/
    Or a local junk yard may have them if they have an R53
  8. MCS02
    Also and this is very important...........welcome to MA!
  9. MCS02
  10. Bartman
    Bartman New Member
    Jan 1, 2019
  11. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    and that oil leak does look like the crank sensor o-ring is leaking. Not hard to resolve once you have the new o-ring. Typically, others use RTV sealant around it too. It'll be obvious once you get in there. It could be oil pan leaking too.
  12. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    here you go
    while fixing the CPS sensor o-ring, do the dip stick tube o-ring as well. Usually both leak at 30k miles or even earlier.
    • Like Like x 2
    • Agree Agree x 1
