New hi/low bulbs
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ScottinBend, Mar 13, 2018.
  1. ScottinBend
    Looking for suggestions on replacing my still working but original headlight bulbs. I have the pre-facelift xenons and would like suggestions for both hi and low beams .
    Thanks
  2. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Surprised there was no response to this question. I personally don’t have any but with all the R53 folks here I’m sure someone does.
  3. MCS02
    My R53 doesn't have xenons so I cant help. Sorry.
  4. wmwny
    4,048
    2,246
    My wife's S has Xenons but we are having no problems with them...so far. MY S doesn't have Xenons but the old bulbs have been replaced at my local auto store in the past with no problems. My R50 has never needed bulb replacements and it is an early '03!
  5. ScottinBend
    They all work, but I am sure after almost 15 yrs there are not as bright as they once were. The halogens are not so much the concern, but having no experience with the xenons not sure about brands and such.
  6. Dave.0
    Call TRS (the retrofit source ). They will have the advice and the bulbs you need and they will not be eBay or Amazon fakes.
    OSRAM and PHILLIPS are OEM but a lot of people sell knock offs to you have to be careful and by from a real authorized dealer. Morimoto is a great aftermarket brand that I use and have not had any issues with.
    https://www.theretrofitsource.com/hid-parts/hid-bulbs-d-series.html
  7. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #7 Qik, Mar 16, 2018
    I'm on the original bulbs yet in my 12'. Stick with OE or equivalent.
  8. DneprDave
    If your xenons are still working, why change them?
  9. Dave.0
    #9 Dave.0, Mar 16, 2018
  10. Dave.0
    Because all HID’s “xenons” color shift overtime and loose brightness.
  11. ScottinBend
    So d2r is what I am looking for my 2004 (10-03 build)?
    I am seeing some sites saying d2s......
  12. Dave.0
    If you still have OEM 2004 lights (before the facelift) you should have reflector HID’s and you use the 2dr.
    Think of it as R= reflectors.
    I would always call them and just be sure.
    The 2ds are for Hid’s With Projectors type lights which are very common now. The 1st gens had two HID set ups and mid run “the facelift” got the projectors.
    The first gen GP is the exception because they used the reflector version to save weight in 2006.
    • Informative Informative x 1
  13. Dave.0
    You can always double check with www.realoem.com and type in your VIN or swing by a dealership If you have one local.
  14. ScottinBend
    Got it, thanks.
    2DR is it.
  15. Dave.0
    Please make sure you take out a bulb and check it for any D2R markings on the base. On my 05 JCW it has d2s on the front of the clear lense that you can see even with the light trim ring installed.
  16. ScottinBend
    Yeah, mine actually shows d2r, d2s and h7 on the edge .Figured that the lens was used for all. But I will verify the base on mine first .
    Thanks
  17. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Good stuff... learned some things based on the comments in this thread. :D
