New member and Clubman owner
Discussion in 'Starting Line - New Member Introductions' started by GreenMiniClub, Mar 3, 2012.
  1. GreenMiniClub
    GreenMiniClub New Member
    Mar 3, 2012
    62
    I just bought my first Mini today! Proud owner of an 08 Clubman, it's a Justa, automatic, with 85,000 miles. Don't know much else. Open to all questions and/or advice.
  2. Justa Jim
    Welcome aboard. Justa's rule. :Thumbsup:
  3. Mr. Jim
    Welcome to M/A!
  4. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Welcome, from a fellow Clubman owner!
  5. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    welcome to m/a from aother clubman owner
  6. Nathan
    Welcome to Motoring Alliance, thanks for joining.
  7. T8rChick
    T8rChick Active Member
    111
    Oak Cliff, TX
    Howdy! MINIs Rule!!!
    Welcome my best Bud & Wife just bought an 08 justa clubster. I love it as does she. I have taken to driving it whenever I can. Sweet rides those justa clubsters.
    Welcome to M/A :)
    My first bit of advice is to change the oil & go over all maintenance items to make sure they are current. The justas are proving to be very reliable.
  9. GreenMiniClub
    Mar 3, 2012
    62
    The dealer said they just changed the oil but I would bet they used cheap Dino oil, I figured I would switch to Mobil synthetic unless there's something else you guys recommend
    I'd recommend Mobile 1 0w40 synthetic. It is what I use in our MINI's. The justa Clubster is a very easy car to change the oil on. There is a nice write up in the library here by Chad of Detroit tuned on how to change the oil.
    You will need an 8mm hex whench for the drain plug & a 27mm socket for the filter. Use an oem or Mann filter. The oem comes with with a crush washer, the Mann does not so you will need to source one if you go with a Mann.
    While you are at it check the air filter & cabin air filter.
