New member but been an owner for 13 years
Discussion in 'Starting Line - New Member Introductions' started by nobbyclark, Sep 28, 2015.
  1. nobbyclark
    nobbyclark New Member
    Sep 25, 2015
    13
    Perth, Scotland
    #1 nobbyclark, Sep 28, 2015
    Hi all,
    Found my way here as I was looking for instructions on how to change my crank pulley.
    Owned my R53 MCS since September 25th 2002, so it is now just over 13 years old. I am just about to add a few mods, hence why I am looking around on this site.
    Have already fitted a Milltek exhaust, K&N filter, Airtec intercooler and Brembo brakes. Have purchased an Alta 17% reduced supercharger pulley and 2% enlarged crank, which will both go on soon, I hope. Also fitting an MSD coil pack, new HT leads and iridium plugs.
  2. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Stay with the OEM coil pack. MSD does not have a quality reputation. AND...welcome to the modness...it's addicting.
  3. ScottinBend
    Welcome!
    Lose the MSD coil (when it fails it can cause some major problems). And you are pushing the limits of heat created by the SC with the 17% and 2%. As long as you have a tune and don't spend anytime above about 6500 rpm it is probably maintainable.
    That IC looks very nice.....have to do some research on that one.
  4. wmwny
    4,048
    2,246
    Welcome to M/A! Obviously, you already know and feel the love we have for our MINIs. Even so, to see a "veteran" new member like you come and join us just adds to the plus side of our MINI addictions.
  5. Stefanie
    Stefanie Well-Known Member
    May 8, 2014
    545
    804
    Sacramento, CA
  6. Nathan
    I'll pile on the Save yer money, don't use the MSD list. Been there, done that. The OEM works best.
  7. wmwny
    4,048
    2,246
    Oops...double post.:eek:
  8. 00Mini
    2,227
    Welcome to Motoring Alliance and good luck with your mod fever !!
  9. MCS02
    Welcome to MA! I have a 17% pulley. I have had my pulley for several years now. I leave in the south where it's nice and hot. I can't remember the delta on the intake heat rise but it is very high. Unless you are going with a better IC or meth and maybe bigger injectors along with a tune I don't think I would go past 17%. With that crank pulley you will be at 19% I know years ago when I researched it 19 could cause problems with the water pump along with too much heat.
    Good to see a new member that's been a longtime mini owner. Nice looking R53.
  10. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    It's best to listen to the group on this and don't install that 2% crank pulley with the 17% SC pulley. It's best to install an original sized ATI or PRW damper. (I prefer the PRW fluid filled damper - no maintenance.)
  11. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the coolest MINI forum on the net..........:cool:
  12. nobbyclark
    Sep 25, 2015
    13
    Perth, Scotland
    Thanks all for the welcome and the useful feedback. I am going to set up a separate post with all my mods, with pics, to chart progress.
  13. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Welcome.
    I tend to disagree that the OEM coil is best. The terminals on the OEM coil tend to corrode. I do agree to stay away from the MSD coil because it does not fit correctly without special screws. I suggest a coil with copper terminals such as the Screamin-Demon or Beru. I like NGK plugs. I OEM plug wires are fine but I like a little color on the wires to add a little bling. Since you plan to do plugs, wires, and coil here are a few good kits.
    WMW Ignition Package - Way Motor Works
    https://www.ecstuning.com/Mini-2002-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Engine/Electrical/ES2581719/
    2002 Mini Cooper S Hatchback - Ignition - Page 1
  14. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Welcome!
    Like you, I'm relatively new here and I have also been the owner of the same MINI for over 13 years now.
  15. nobbyclark
    Sep 25, 2015
    13
    Perth, Scotland
    Thanks for the comments about the MSD. Unfortunately I had already fitted it before I read all of the above. And unfortunately I had overtightened the supplied bolts and cracked the head beneath. Now I know why the BMW coil pack has a sheaf around each of the screws, presumably to stop them travelling down too far!
