Way Motor Works is excited to have the newest and best NM Oil Catch Can available for R55 R56 R57 R58 R59 MINI Cooper S with N14 Engine. The new NM catch can has a multi stage method of condensing the oil out of the crankcase vapor and preventing it from entering the intake. As the oil enters the catch can it hits a wall causing much of the oil to condense, then the air passes into the bottom of the can through smaller notches. There it goes through a stainless steel mesh collecting even more oil. After that it finally passes through machined holes like a screen before it exits the can. If that wasn't enough look at the perfect aluminum machined fittings, and ideal mounting bracket to hold it. With the direct injection a good oil catch can will cut down on carbon buildup and save you from costly repairs from buildup.
