Brakes Wheels 1st Gen Tires New pads.....
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ScottinBend, Aug 10, 2009.
  1. ScottinBend
    Ok....need some opinions as to my new pad purchase. I am not happy with my Hawk HPS pads. They have never really been very good for my driving style. They are fading fairly rapidly during my 1/2 to full hour twisty drive.
    So I am now looking for a step up in performance.
    Are the Hawk HP+ much better? How about either Carbotech or Porterfields?
    My powerslots still have plenty of life, so I am planning on keeping them (unless someone has a good reason not to.....)
    :Thumbsup:
  2. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    How about Ferodo 2500, or Hawk HP+? A Hawk HT-10 is probably too aggressive for daily driving, but may not be unreasonable for a track/fast-street option.
  3. BThayer23
    Maybe try the Carbotech AX pad or the Porterfield R4. Lots of dust, but better fade resistance and braking power.
    R4 is more of a track pad and they are not rotor friendly when cold. The R4S is street compound. Frankly I've not been enamored with either on the front, I do run the R4 all the time on the rear.
  5. BlimeyCabrio
    The Carbotech AX6 is a hella pad for the twisties - what I use for my mountain and Dragon runs. But as Ben said - VERY dusty, and also noisy. Not what most folks would want to run for a daily driver pad. But if your noise and dust tolerance is high, you'll probably love them. I put mine on before mountain weekends and take the off when back home.
  6. ScottinBend
    Thanks all.....
    So no one has any experience with the Hawk HP+?
    I do have a high tolerance for dust and noise and I may be asking too much from my pads. We have winter here so cold temps need to be addressed. I may just have to swap the pads at the same time I do my winter tires.....
  7. btwdriver
    btwdriver New Member
    I have used the Hawk HP+'s on the track in a pinch. They were not that great on the track (they basically started crumbling under the heat) but they would probably be fine for twisty street driving. If you have a descent tolerance for noise, you might also try the Carbotech XP8's. They were pretty good on the track, and should hold up to any type of street driving you will be doing.
  8. ScottinBend
    Thanks.......
  9. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    #9 mini_racer, Aug 13, 2009
    So SB, what are you gonna go with? I am thinking about the HP+ myself for some occasional track duty with my JCW brakes, they have got to be better than the ceramics I have run.
    See the other thread on JCW brakes. There weer some recommendations of CarboTech, but they aint cheap, it does seem like a good product though. And being able to trust/depend on your brakes is kind of important.
  10. btwdriver
    The HP+ are NOT a track pad. I would suggest moving to a dedicated track pad like the HT-10.
  11. mini_racer
    Engr Manager
    Thanks Brian, dedicated is what I am looking for, I am fine to swap pads for the track. I just checked out the Hawk site and the HT10s are three notches higher than the HP+, that is significant. I know you have some experience with the HP+ and will use them in a pinch, do you have any better experiences with the HT10s?
    While I am sure the HP+ would be better than the Hawk ceramics I have risked my life with in the past, going a few notches even better can't be bad.
  12. btwdriver
    I have not personally used the HT-10's as they are not available for the R56. Scott uses the HT-10's as his track pads with good success, (hence my recommendation). I have personally used the Carbotech XP10's in the front and they are a pretty good track pad. If you contact Dustin at AutoXCooper.com, he will be able to give you a better price than the list price.
    I have used the HP+'s in a pinch, I don't know that I would do it again. After just a single day of use, the pads were crumbling. I would be afraid that after 2 days of use, the pad might separate from the backing plate, resulting in catastrophic brake failure.
    Note: I seem to be particularly hard on brakes, so YMMV. Having lost brakes while on the track, I also take a pretty serious outlook on ensuring my brakes function properly. Things like "Just don't use your brakes" are funny, and I have been know to say them. But when you are heading into a hairpin at 100+, brakes become serious business fast. Threshold braking leaves zero room for mistakes/issues.
  13. mini_racer
    Engr Manager
    Thanks for the great info. I will give Scott a yell. And I here ya on the importance of the brake system, I am sure those ducts will make a difference for you. Keep 'em cool, or at least cooler!
  14. ScottinBend
    Still not sure what pad yet, but I would like to try and stay away from a dedicated track pad. My track days are few and far between right now and the track I can go to is fairly easy on pads.
    I am leaning towards the HP+ or even the Carbotech 6's right now.
  15. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    We are also Carbotech dealers and MA site sponsers. FYI
  16. AMG-RX7
    AMG-RX7 New Member
    Oct 7, 2009
    36
    Mountain View, CA
    Anyone recommending Hawk Ht-10s for the street is nuts. I run them on my RX7 for balls out track driving. I couldn't get enough heat in them for street usage, they are noisy buggers when cold and will eat your rotors driving them cold on the street. I've run the R4 and R4E on the RX7 for track usage also. Good track pad not a street pad.
    The HP+ might be an option but they do dust like crazy and are usually noisy. Lots of autocrossers use those pads. Its definitely an older technology brake pad formulation like the Blues.
    I'd personally try the Carbotechs. I know a lot of people that love their pads and will be trying them myself on the Mini when the times comes. I was actually speaking with Way Motor Works on the phone a couple of days ago about the Carbotechs. Good, helpful people.
  17. howsoonisnow1985
    howsoonisnow1985 New Member
    Aug 8, 2009
    171
    Inmate
    Santa Cruz County Jail
    #17 howsoonisnow1985, Oct 16, 2009
    I have Hawk HP Plus pads, they have a very aggressive initial bite, you have to be very smooth with brake application. Like others have mentioned it is not a track pad, that being said I took it to 3 DEs this year and there was some significant fade by 3rd and 4th session, but like someone else mentioned they were smoking hot, I mean they really looked like I stuck smoke bombs on calipers. On the street they are great, if you don't mind the screeching sound at moderate application like stop signs or at lights, especially in cold weather or mornings. They do dust, but I have black wheels and don't really notice that type of stuff.
    Edit: Forgot to mention I got JCW R53 Brakes.
  18. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    What would you guys recommend for street driving. I can't believe the dust on the OEM pads :(
  19. BlimeyCabrio
    If you don't like dust, and like stopping power, Carbotech Bobcats.
    If you don't want to spend that much, Hawk Ceramics (but they eat rotors faster).
  20. ScottinBend
    My Hawk HPS don't dust as bad as the stockers did.
