Suspension Brakes New Shocks = Alignment?
Discussion in 'Tuning and Performance' started by Dwight, May 2, 2011.
  1. Dwight
    Dwight Racing with the Gods
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Just ordered a set of Koni Sport Adj. shocks for F/R. Not changing anything else, but will I need an alignment when done? I don't think so, but ain't at all sure. Thanks! :confused5:
  2. 1972Austin
    1972Austin New Member
    Mar 20, 2011
    33
    Yorktown, Va
    Anytime you alter your suspension (guessing you are lowering some) you should get the alignment checked to be sure. I know, first post but I swear I might know something.
    Shawn
  3. Dwight
    329
    12
    RETIRED!!
    San Marcos, Calif.
    I am only changing shocks/struts. The car is already lowered 30mm and was re-aligned at that time to compensate. Thanks anyhow! :Thumbsup:
    Yes, cause you are pulling the springs and perches out to make the change. While it might look like it all goes back the exact same it doesn't.
    Give it a few days to settle in and then re-align.
  5. Dwight
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Will do and thanks much. :Thumbsup:
  6. DneprDave
    #6 DneprDave, May 3, 2011
    I dunno, the only adjustment I can see is the toe. If you haven't had the steering knuckles off, I don't see any reason to do an alignment.
    Dave
    +1 ^ :yesnod:
  8. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    depends on how many potholes you hit since your last alignment:)
  9. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I do not think there is enough reason to spend $100 on an alignment after changing shocks (strut R&R) if you know the alignment was good before the shock replacement.
    I would instead use the funds towards camber plates. IE Fixed plates are only $180.
    If you install IE fixed plates (highly recommended) you will need an alignment. Adding them will cause your MINI to go toe-in.
  11. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Good point about the alignment after camber plates.
    Kind of negates my justification for Dwight to spend more money on mods.
  12. Dwight
    329
    12
    RETIRED!!
    San Marcos, Calif.
    I don't do camber plates. With the exception of the Koni shocks, the suspension mods I've already done (see sig.) have produced the results I wanted. Dead neutral handling.
  13. ScottinBend
    Get an alignment.......consider the cost of tires. An alignment is the same as a single cheap tire.
  14. 1972Austin
    Mar 20, 2011
    33
    Yorktown, Va
    Regardless of whether your alignment was good you never know what might change. It's just piece of mind as tires aren't cheap as stated above. I have lifetime alignments through Firestone so anytime I do anything it's in for a free alignment! Pays for itself.
    Shawn
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Dwight,
    I suspect you'll need one for the reason Nate outlines
    Drive it around a bit see how the car responds
    New Koni's? nice!
  16. Onramp
    Onramp Enjoy the Hiways of Life!
    Retired, mostly
    Renton, WA
    I'm with Scott, especially if you are still on the run flats. A possible bit of ride height change, a bit of twist on the reinstall, and you will start some funny wear on those very expensive tires. I tend to have alignment checked every year. Western Washington roads aren't very good anymore, and two of our local tracks have some brutal sections. The before and after specs are enough to convince me. An alignment is cheap, improves mileage and drivability. Just do it.
