Brakes Wheels 1st Gen Tires New Shoes for GNAT
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Nathan, Aug 25, 2010.
    I actually wore out a set of street tires before selling the wheels. New Yokohama AD-08's ready to installed thanks to a very friendly Discount Tire.
  2. Minidave
    4,592
    Did you get your engine problems sorted out too?
  3. CHKMINI
    Nathan, do these replace the ones you had to put on in Indy?
    I don't know, odd things are afoot. I'll be posting about that later.
    Only had one tire put on in Indy to replace the one with a cut in the sidewall. As I needed something quick it was close to the correct size. Later that day is was given a tire of the correct size by and Indy local, However, it was the wrong type and it was fairly new so the car had a little bit of push to the right. This newer tire was on the left rear.
    The other 3 were pretty close to being worn before I left so it made sense to get a new set. I've wanted to try these AD-08's and between the rebate, instant discount and MM.org discount we have locally at select Discount Tires it just made sense to do it now.
    They look sharp on the car, it is raining here now so I can't tell how they stick, besides they need a few 100 miles to scrub in and wear off the mold release.
  5. beaner
    beaner New Member
    44
    you should mount them on some new wheels, just to keep your record intact!
  6. Metalman
    One word...................
    JONGBLOED
  7. beaner
    beaner New Member
    44
    Shhhhhhhh. I'm trying to sell him my Kodiaks so I can order my Jongbloeds.
  8. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Friend just insgtalled these on a miata and likes them quite a bit. Before this he was on some kuhmo XSs and actually prefers the yokos. B/C of that I may giving them a spin to compare to the star specs I had. All this to just say; good choice!
    What size tires? And what are the specs on the wheels they are being mounted to?
  9. Nathan
    Size is 215/40-17
    Wheels are Work VS-XX polished lip, anthracite centers with black hardware as seen in my Wheel Rack entry.
  10. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I've only heard good things about these tires so it will be interesting to see.
  11. BThayer23
  12. danf
    danf New Member
    Aug 30, 2009
    33
    I'd be interested in how these compare to direzza's. I've been on direzza's for a couple of years now and would like to try something new.
  13. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
    They wear much quicker the the Bridgestone RE-01Rs, so not that good of a daily driver tire... however they do stick quite nicely.
    I'm about half way through a set with about 8k miles on them. No opportunities to get on the track this time, but others have also mentioned how they like them.
    I think there's an actual thread on the AD-08s here somewhere :Thumbsup:
  14. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    I think the Yoko's look really nice, but I opted for the lower priced Hankook Ventus V12s which were also recommended by several on MM.org. Getting them put on Saturday. Also at the same friendly Discount Tire location. 215 45 17
  15. minimark
    Love my ADO8s, much stickier than my old REO1rs and they are lighter but......I don't run them everyday, keep them on a set of light wheels for track days and hitting the twisties! Not a daily driver tire unless you like buying tires often.
  16. Nathan
    Had a bit of rain yesterday, just quick downpour thunderstorms but I went out to see how the wet performance is. That was fun :yesnod: Sure are some sticky tires, even when wet.
  17. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
  18. minimark
    From my time with them on the track Nathan, they don't like as much air as some tires and are sensitive to small changes in pressure. Keep up with them and don't be afraid to take air out between sessions... Do that and you can really punish them without the give up of some I've run..... much quicker turn in too than my previous REO1Rs. 2 cents
  19. Nathan
    Update: I really like these tires. For me they are quite good, the grip levels on the street are insane. They feel great, respond quickly and stick like glue. Not sure if I would use them on a daily driver due to the cost. Also have no idea how they work in cold weather but to me these are not issues. It doesn't often get very cold here in North Texas. My commute is not like most either, my biggest obstacle is making sure I don't overfill the coffee cup so not to spill in the carpet as I navigate around the ottoman in my trek across the living room to my office.
  20. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Yeah, nice specs on that tire. I believe many use it as their street/track combo tire given a treadwear of 180. I bet it is pretty sticky.
